Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Not the blinking green light problem, but maybe close
Sometimes when the set is powered up the green light comes on, but the lamp does not come on (1 out of 5). I unplug it for 10 sec. and try again. Usually lights up & works fine. Sometimes I must unplug a second time. Wondering if this is the same bad cap problems others talk about or is something else? Had a tech look at it. He said it was likely the DM board.
  • Mitsubishi Master
  • 8,617 Answers
Its most likely the capacitors on the power PWB which is causing the lamp abnormality. The DM would cause the led to blink continuously. There is a repair kit for the power pwb called the V26 power pwb repair kit available at the following link.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
When I turn the TV on it comes on for 1 min or so then turns off. I get the green blinking light by standby/power button. Then it comes back on....then off again.....then on. It just comes off and on...
Has the Lamp been replaced yet if not replace it pull backoff watch Fan to Lamp if it stops running while Lamp is trying to turn on Lamp will turn OFF FAN maybe defective. For Parts Call Encompass 1-800-638-3328 Clean out all dusty dirty Fans and around Lamp housing.
Oct 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Replaced the lamp, still wont come on.
1- Did you make sure you have the lamp door on correctly, there's a safety switch that activates and wont let the lamp light for your protection.
2- Put your ear close to the lamp door and listen for a slight hum as soon as you turn it on, it will go in cycles. If you don't, it's going to be the ballast module or the color wheel, both these have to be working to let the lamp light. I suggest you call a service center after that, that's the best thing.
Feb 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Zenith z44sz80
the light next to the power light is the lamp indicator when it blinks red it means there is a problem with the lamp . if its orange it means its getting close to the end of its life span.let me know if you need anything further .
Apr 13, 2008 | Televison & Video
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
