Question about Akai LCT3201AD 32 in. LCD Television
I have a 32" HD AKAI TV that keeps turning itself off
My TV keeps turning itself off. It will turn back on for about 30 seconds when we hit the power button on the remote, then it turns itself off again,. The number on our TV seems to say LCT3215A
  • 2 more comments
  • mkdebord Nov 04, 2008
    We ended up having to return the TV to Radio Shack, where we bought it, and got a new TV from them to replace it. A bigger, better TV. Evidently no one services AKAI TVs around these parts. We did all of this before receiving the email above from you all.
  • Mona Masters Nov 30, 2008
    While my problem is not identical it is very similar. The screen saver was on when I came into the room, so I hit a button a couple times as the screen stated to remove the screen saver. When it stayed in the screen saver mode, I powered it off. It has not come on correctly since. When you turn it on their is a dull whine and it is as if there is a DVD in there, but there isn't. The black screen comes up, then the blue screen with the AKAI emblem as soon as you can see the AKAI the stupid thing shuts down. PLEASE HELP IT IS DRIVING ME CRAZY!
  • Anonymous Jan 10, 2009
    MY 2 YR OLD AKAI #LCT3201AD TURNS ITSELF OFF-I HAVE TO UNPLUG IT FROM THE WALL OUTLET FOR A COUPLE MINUTES-IT COMES BACK ON WITH THE REMOTE OR SIDE BUTTONS BUT TURNS OFF AGAIN AFTER JUST A FEW MORE MINUTES OF PLAYING-THEN I HAVE TO GO THROUGH THE PROCESS AGAIN AND AGAIN AND AGAIN! NO MATTER WHICH SOURCE I'M USING IT ALWAYS DOES THIS. THE PICTURE AND SOUND ARE GREAT BUT THIS IS DRIVING ME CRAZY. I CAN'T WATCH A SHOW OR DVD WITHOUT PUSHING THE PAUSE BUTTON THEN CONTINUING AGAIN AND AGAIN AND AGAIN! PLEASE HELP ME!
  • Mona Masters May 11, 2010
    My husband tried solution #2 and that did not work for us. Anything else we could try here b4 I try to find a shop to work on it? Thx
    I am willing to try anything!
  • 3 Answers
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
  • Toddo7 Jun 07, 2011
    Thank you roomwwidavu!!! You are the man. I have the 32" Akai and it had the "turn on then turn off problem". I am handy, so I followed your advice. I took the TV apart and pulled the power supply board off the TV. The three electrolytic capcitors in between the heat sinks were indeed bulging. And the other three electrolytic capictors on the other side of the heat sinks were bad too. Two of those were actually leaking some brittle cyrstaline black **** and the third was bulging. And also a big 450v 1000uf cap in the middle of the board was bulging also. I replaced all seven of them and the TV is fixed!!! I only paid like $7 dollars for all caps from a local electronics supply store in my area.
    The three caps in between the heat sinks were originally 1000uf 16v as you said. I replaced those with 1000 uf 35v because they were out of the 25volt. It was a tight fit but I managed to jam them in there. The three on the other side of the heat sink were two 1000uf 35v 's and one 22uf 25volt. I replaced the 22uf 25v with a 22uf 50volt, and the other two 1000uf 35v with the same specs, 1000uf 35v. The big one in the middle I replaced with the same specs, 1000uf 450v.
    It was not that hard to do at all. I had modded an old Xbox before, so I did have a little experience with soldering on a circuit board. The hardest part was getting the old solder out with desoldering braid. The job would have been much easier and MUCH faster with a solder ******.
    For those out there who do this, make sure you get the polarity of the capcitor matched with the board. The caps have a negative side marked and the circuit board shows which lead is negative. I accidently got the polarity switched on the first one I did and had to take it back off and redo it when I notice that the caps had polarity marked on them.
    Push the lead throught the holes (with correct polarity) flip the board over and solder them in. The solder beads up and stays right in the little square contact area. After you get the leads soldered in, THEN cut the leads off flush with the top of the solder bead. Don't cut the leads off before you push it through the board.
    The guy at the electronic supply store did confirm that the 1000uf 16v caps were a manufacturer deffect. He also confirmed (as you said) that you can increase the voltage spec on the caps, but not decrease the voltage spec. He recognized the Akai power supply board without me even telling him what brand TV it came from. I guess he's seen a LOT of those messed up boards.
    I just successfully reapaired my first TV hahahah!!!!! Thanks roomwwidavu!! You saved me $200
  • FixedMyTV Sep 04, 2012
    Thank you roomwwidavu and Toddo7!!!! I had the same issue and the three 1000MicroF 16V capacitors between the heat sinks where the issue. They were bulging and once I replaced them with thee 1000MicroF 25V capacitors, the issue was fixed. Challenge was removing the old components out with the desoldering braid. But it was not too bad. and not to mention the 15+ screws to I had to take out and put back in! - but hey, it did save me a lot of money! Thank you for your detailed guidance!!
    Scholar:
  • 124 Answers
Hi, The problem comes from the power supply board. You can have the power supply board repair or replace. I understand that this part is VERY hard to find. Everywhere I have contacted, they do not have any in stock and cannot get stock. Your best bet is to have it repair. To have it repaired, click on the below link http://www.power-supply-repair.com/ If you have any additional questions, please feel free to contact me asap. Thanks, Mike
Posted on Nov 01, 2008
  • 35 Answers
Hi
This is power supply board problem.I saw on ebay chipper pries.Please check:
AKAI POWER SUUPLY BOARD LCT3201AD MLT169A
DS
Posted on Jan 16, 2009
I have a akia lct3201ad tv and it wont turn on. ipush the power and the green light comes on for a few seconds and then turns off. i got it to turn on a couple of times and i just got a grey/green screen with no picture. what do i do ? it is only 2 years old
Posted on Nov 08, 2008
I am having the same problem ,does anyone know if this applys to a 26" tv with a dvd player atached to it ? thanks
Posted on Aug 21, 2011
I have a Emerson model LF391EM4 flat screen that when turned ON shut itself off after apx 10 seconds. It has never done this before, what can I try to do?
REBOOT IT BUT HOLDING DOWN ON THE POWER AND TURN IT BACK BUT HOLFD IT DOWN FOR ABOUT TEN SECONDS AND THEN TURN IT BACK ON
Jan 09, 2017 | Emerson Televison & Video
I HAVE AN AKAI HD TV DVB-T32W. When I started out first time, it autoscans but found no channel. press DTV or ATV, it,says "No channel. need to rescan". But nothing happens, thanks
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 09, 2017 | Akai Televison & Video
Hi Bush tv is flashing but not turning on at all. What can i do?
Hi press & hold on-off button while holding unplug power plug from the wall continue holding for 30 seconds.,.Plug in the POWER plug while holding on/off button hold for another 30 seconds ......,.Good luck.,
Jan 08, 2017 | Televison & Video
Sound is pinned at 100% output. Remote nor physical buttons on device are working.
If any of the buttons on the remote or tv work, then try going into the menu and turning the sound down manually.
My Toshiba 46g31ou tv keeps shutting itself off and on by itself.
MUST BE IN THE SETTINGS OF YOUR TV WHERE YOU CAN CHOOSE TIME FRAMES FRO IT TO TURN AND OFF ITS A POWER SAVER FEATURE
Nov 30, 2016 | Toshiba Televison & Video
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Akai LCT3201AD 32 in. LCD Television Logo
3,026 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
