Question about Toshiba Satellite 1405-S151 Notebook
Hard drive removal? Satellite 1405-S151
Can someone please explain how to get the hard drive out of a Satellite 1405-S151
Thanks,
Anthony
    Genius:
  • 1,124 Answers
How to Add or replace your Hard Drive
1. Turn off the notebook, remove the power cord & battery
2. Use a screwdriver to remove the two screws that hold the hard drive compartment panel in place. (on the bottom of your laptop)
3. Gently lift the panel and slide it out.
4. You'll discover that the hard drive is bolted to the panel with four screws. Use the screwdriver to remove the screws. Separate the hard drive from the panel.
5. Slip the new hard drive into the panel and align the screw holes. Replace the screws.
6. Put the panel back into place and make sure it locks
7. Replace the two screws that hold the compartment panel in place.
Posted on Oct 10, 2008
The original hard drives for the satellite a45-s151 is a 2.5 or 3.5
Original hard drive for the Toshiba Satellite A45-S151
60GB hard disk drive, enhanced IDE (ATA-5) interface, 4200rpm drive rotation, 9.5mm height, 0.2lbs, service removable.
Nov 17, 2011 | Toshiba Satellite A45-S151 Notebook
How do i factory restore toshiba 1405-s151? Is there a restore partition?
Yes, there is one. The hard drive is split into two patitions. Have a look.
If it is still intact then F8 will guide you there.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite 1405-S151 Notebook
Am not able to get drivers for Thoshiba satellite 1405-S151 laptop
sanathanchan,
Here is the website for driver support for your model of Toshiba Satellite:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=191872&rpn=PS140U&modelFilter=1405-S151&selCategory=2756709&selFamily=1073768663
Hope this helps.
-S
Oct 19, 2010 | Toshiba Satellite 1405-S151 Notebook
Question about the toshiba satellite 1405 s151
This is an older model and should have a celeron chip in it.
I dont think you can update the processor.
Check the manual
Aug 30, 2009 | Toshiba Satellite 1405-S151 Notebook
Ccmoon
The hard drive is located under the laptop (near the front) with "disk" icons on it held down with a screw.
Remove the screw and get a thin flat headed screwdriver and gently pull the hard drive cover off, you may hear a couple of crunches but this is normal as it will be the securing tabs coming away.
Good luck.
Aug 20, 2009 | Toshiba Satellite A45-S151 Notebook
Toshiba 1405 s151 will not turn on. the green light for the plugin is on. i let it sit overnight but it will not do anything when i hit the power button.
remove the battery and power .CLEAR THE bios by removing the small battery on the mainboard for 10 hurses and power it on.
Aug 05, 2009 | Toshiba Satellite 1405-S151 Notebook
I want to upgrade the hard drive in my satellite 1405-s151. how big of a drive will it handle?
As big as your willing to spend. I would suggest a 320 or better. You will not have to worry about running out of space then. Just make sure you get the correct type of hard for your system.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 14, 2009 | Toshiba Satellite 1405-S151 Notebook
Manual
To download Toshiba Satellite 1400/1405 manual, please click the link below:
Thank You
Nov 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Me again
go to the bios and load defalt setting and restart
Apr 02, 2008 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
362 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
