Hi, I have a 49.9C02 error message on my HP CP6015dn printer, have turned off as suggested, removed the network cable but does not fix the printer. Any suggestions or do I need a technician to look at it.
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
SOURCE: HP Officejet 5610 All-in-One--Cartridge Error
If a reset hasn't cured this problem you probably need to disassemble the printer and clean the service station and the system board. This normally clear all carriage and cartridge errors, but these machines are quite awkward to take apart.
SOURCE: HP 7310xi: "Remove and Check Printer Cartridge on the right"
Sounds like the carriage is broken on the black side. Pull the cartridge out and take a look at the silver metal piece. Is it loose from the side and if so did it punch a hole in the circuitry that cartridge comes in contact with. If I were a betting man this is probably your problem. You have to replace the whole carriage. This is a pretty common problem with the carriages that use the #96 and #97 cartridges.
Inkworks
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
SOURCE: LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on
Description
The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action
