Green and red colors seperated
Samsung tv When I turn it on it goes to menu with double words, one green and same word lower but red.
  • drwright2 Oct 10, 2008
    standard
  • Inno Laur May 11, 2010
    Is this a standard set or a rear projection?
    Scholar:
  • 92 Answers
Other than the menu, does the picture look ok? Does the menu just stay there and not go away?
Posted on Oct 14, 2008
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
Double picture & color problem
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
