Question about Ricoh 6513 Copier
Dead 6513 / PSU failure
I just got a 6513 copier which I had to dismantle for it to be transfered to my workshop. I managed to reassemble the machine and get it back to working condition. BUT when I reinstalle the Fiery controller it blew the main PSU and now all is dead. As there is no circuit diagram available is there anywhere you can suggest where I can perhaps get a second hand workig PSU.
regards
Saviour
  • Ricoh Master
  • 2,794 Answers
Goto copytechnet.com.  That site is like fixya but it's copier technicians only solving problems.  They should be able to help you with the PSU diagrams.
Posted on Oct 14, 2008
Smells like burning
what system? are you on, PC, DVR, mac, what?
can never be good that.
as always, first find out what smells bad.
then post back here.
if the hdd is actually smoking, (surely a rare thing)
if the drive is dead in 2 systems it is dead.
if partial dead, there is recovery software you can buy.
the #1 PC smoker is the main powersupply the PSU.
the solution is a new one.
Oct 05, 2013 | Western Digital Computers & Internet
Ricoh colar 6513 cod sc 457
SC457 mean Image Transfer Belt Cleaning Unit Position
Error, try to clean the sensor in the transfer belt with a dry cloth.
Jun 21, 2010 | Ricoh 6513 Copier
THE COPIES ARE COMING OUT WITH BLACK STREAKS. LOOKS LIKE SOMETHING COULD DO WITH CLEANING. IS THIS A JOB FOR ME TO JOB OR AN ENGINEER?
This machine uses a single drum and cleaning unit and a transfer belt assy with its own cleaning unit. That being said if one color is steaking they all would streak. My 1st guess without seeing copies from the machine would be that your problem is fuser related look in the fuser especially around the fingers for damage to the roller (this is common on these.
Good Luck
Mar 01, 2010 | Ricoh 6513 Copier
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
I have a ricoh 6513 and when I print out a test page the yellow registration is slightly off to the left from CMK in wich it creates a slightly yellow blur is there an adjustment tha I can do
I think you can solve this by take the image transfer belt out and clean inside , sensor , roller and timming patch. There are also service program to adjust this problem which I have see before but right now I could not recall. Good luck
Mar 20, 2009 | Ricoh 6513 Copier
Ricoh 6513 - no power
There is no schematic available. Only point to point wiring for the various modules. If you have no power at all, nothing starts glows or blinks on the control panel or on any of the various boards then you will need a service call to try to resolve the problem. It may require a board swap to see if that board is at fault. Unfortunately the days of repairing boards are long gone. Sorry!
Dave T
Jun 02, 2008 | Ricoh 6513 Copier
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
Ricoh 6513-Blank copies
hi im jules_09,check the transfer unit then the drum charge unit blank copies indicate that there is no high voltage that attach the toner to the drum.
Nov 15, 2007 | Ricoh 6513 Copier
14h error
14: 2nd image transfer pressure/retraction failure
Relevant Electrical Parts
Retraction Position Sensor /2nd Image Transfer
(PC5)
Pressure/Retraction Solenoid /2nd Image Transfer
(SL4)
open cover, remove image transfer unit, behind ITU is 2nd image transfer roller, move it with hand, check solenoid and sensors, thaht they moving freely.
restart
good luck
Nov 11, 2007 | Konica Minolta magicolor 2400 Laser...
Ricoh 6513 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
