Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
My vacuum is very loud ...
We have checked for clogs and cleaned all the filters, but it is still very loud. Annoying loud.
  • mzztrip Dec 30, 2008
    my vacuum is extremely loud. but seams to work well. any thoughts?
  • 107 Answers
If it sounds really high pitched or like a airplane i would bet your motor is shot in which case it would exceed cost of your unit.
Posted on Dec 09, 2008
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum is loud
Check for clogs starting with the air passageway at the bottom....
a piece of TV cable is great for clearing clogs there....check all
hoses...check for dirty filters. If you find no clogs remove the
brush bar and belt and start the vacuum...if the vacuum is no
longer noisy the problem is the bearings at each end of the brush
bar..... WD 40 may fix or you will have to replace. If after all this
the noise persists the the problem is in the motor. (If you use WD 40
make sure it is dry before you vacuum carpet)
Regards,
Dennis
Aug 15, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Very loud, great suction but too loud to use
Hey Jim! Dirty filters or clogs can cause a vacuum to sound louder than normal.
We've got some great How-to-Videos that can assist you with how to check and clean them. Here's the link: http://www.bissell.com/how-to-videos/?cid=ccsocial
If you're still having difficulty, one of our Authorized Service Centers can inspect the vacuum. Here's the link to finding one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 15, 2013 | Bissell Vacuums
Its making this loud really loud sound when on not like normal
Clogged lines, clogged filter or hair tangled on the moving parts. Take apart and clean as needed.
Apr 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Dyson DC07
First, check all of the ports, there are various covers you can take off to see if there is a clog, also check the hose for a clog. Make sure all filters are clean out. The worse case would be a motor problem.
Feb 14, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson noise.
Check all ports for a clog, there are removable covers you can take off, also check the hose for a clog. Make sure all filters are clean. Worse case is a problem with the motor.
Jan 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
1,439 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
