Turntable does not rotate when switched 'on'.
Direct drive turntable does not rotate. Turn power switch on and unit comes to life. Turn the 'self-return' lever/switch to 'on' for the record deck to start rotating but turntable does not rotate. Manually turning of the turntable engages the pick-up arm so mechanical link is OK there.
  • 2 more comments
  • accosnr Oct 10, 2008
    Hi inno73. Turntable is on Aiwa 5600 Sound System (a number of years old); tape player. radio, record deck combined. It is single record manual loading. The system belongs to an aged relative so am trying to help get it back OK for him. The switch to operate the deck is self returning so must engage some system/mechanism to get the turntable rotating and then maintain power to the motor until record is finished. But no response from the switch. I am told it was working OK then just stopped responding. Maybe it is the switch itself or perhaps the motor gone down; any further suggestions/comments appreciated.
  • accosnr Oct 13, 2008
    Inno73, Can't hear any hum local to the record platter when the switch is operated. The switch is black, pushed forwards against a spring return with only one move. Thanks again for the info.
  • Anonymous Dec 25, 2008
    I have a sears combo stereo (am-fm/tape/record player). The tunrtable won't turn, although the motor runs. I took off the platter and it appears it is driven by an idler wheel. The outside edge of thew wheel and the inside edge of the truntable have odl, sticky grease on them. The drift shafts spins (and changes rpm, as it should) but when I put the platter back on nothing happens. Any ideas? please send replies to cptjnw@yahoo.com. Thanks
  • Inno Laur May 11, 2010
    What brand of turntable is it? Is it one of those record stackers that automatically drop the next record? If so, the mechanisms on those often get gummed up as a result of the lubrication (grease) drying out and it makes the gears very hard to turn.
    If it's not one of those, please post a make and model.
    Scholar:
  • 92 Answers
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Posted on Oct 11, 2008
2 Suggested Answers
SOURCE: Turntable does not rotate when switched 'on'.
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
Posted on Jun 03, 2010
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Turntable doesn't turn
Most turntable motors are under 12 volts. What you can do to test it is remove it and attach a 9volt (PP9) battery to it. If that doesn't turn it then the motor has gone. If it does, either the power isn't getting to the motor or there's a faulty switch somewhere.
This solution is no good for direct drive turntables, but most of them don't use belts.
Dec 03, 2012 | Audio Players & Recorders
Turntable will not rotate when in "Phono" mode
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
Jun 20, 2010 | Crosley CR78CD-P CD Shelf System
Aiwa AP-2600 Direct Drive Turntable - platter not rotating
if the platter is removable by you and easily, might need just a little cleaning and lube at the center . the platter is the top rotating plate that you were pushing to get started.simply pulls out around a center key. check with local service shops how much they would charge for this kind of cleaning and lubing. $25.00 might be a good price to allow a decision, whether to buy a new.
Mar 05, 2010 | Aiwa PX-E860 Turntable
No power when i turn on my mk3 turntable
Check the internal fuses. There are two. You have to strip the unit down to get to them.
This video will show you what's involved:
http://www.youtube.com/watch?v=CDYgjwdQ55s&feature=channel_page
Aug 17, 2009 | Technics SL-1210 Turntable
Feb 08, 2009 | RCA ION-ITTUSB05 Turntable
Direct drive turntable will not rotate
If it does not rotate, more than likely the belt has either come off, or is broken. Lift up the turntable platter, and you'll see what the issue could be. The platter just lifts right up.
- OPTiC
Turntable Technician
Dec 27, 2008 | Sony PS-LX250H Turntable
Power switch woes
take out all the screws and open up the case.. you should see the post by the switch.. its slid down into the player. carefully push the post back up (not bending anything), dab some glue on the tip and place the knob back on.
Feb 20, 2008 | Technics SL-1200MK2 Turntable
Technics sl-1610 mk 2 turntable
Unfortunately, it does sound like a drive issue. Just so you know, these units are direct drive, so there is no physical motor. It's just a bunch of various circuits which drive the unit, and if any one of them go bad, it will affect your turntable speed. You will need to have this looked at by a service technician to determine which circuit is faulty.
- TWEAK AV LAB
Nov 26, 2007 | Technics SL-1200MK2 Turntable
735 people viewed this question
 Grubhead
Grubhead
