Question about Car Audio & Video
Protect led light
I have a question. my green led light goes on when i turn the amp onbutas soon as my headunit sends the signal to the amp the red protectlightgoes on. i disconnected the rca's and the speaker wire and when iturnedthe car on it stood green the whole time. im having problemsthoughfinding a ground in my trunk. ive been hooking up systems since2001 andnever ran into this problem... any ideas?? italysfinest818@hotmail.com
I plugged up my amp correctly any it stays in protect mode no blinking or anything. I checked my ground and power, it was fine. Then I checked my Remote wire it was fine. I then plugged up my sub and it didn't work. I waited the 10 seconds to see if the protect light will change and it didn't. Any advise.
Posted on Mar 26, 2011
  • 631 Answers
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Oct 11, 2008
I have a 100 watt kicker marine mono amplifier in my ATV, as soon as I switch the amp on the FM radio drops completely out. The amp is grounded well, and independent from all other electronics, also the...
does the light on the amp change from green to red, or does it just not turn on because what it sound like is the headunit itself is messed up and grounding out with the amp when you switch it.
Sep 19, 2013 | Car Audio & Video
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Where can i get a free copy of schematic diagram for amplifier
Generally a "protect" mode would be triggered by a shorted output (speaker). I would suggest disconnection all of the speakers to see if the red light goes off.
Mar 16, 2009 | Car Audio & Video
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Question on BB2125 2 Channel Amp
Hi jgoudie
It is a signal sensing turn on unit, so will not turn on until you have supplied signal to it. Plug it into a signal source and see what it does. But unfortunately, in my experience the protection light coming on means there is a fault in the amp.
You can download the user manual for the amp from here. Click downloads in the middle of the page:)
regards
robotek
Aug 17, 2008 | SpeakerCraft BB2125 2-Channel Amplifier
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Amp has Red LED light on.
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
Car Audio & Video Logo
708 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
