Question about Dell PowerEdge 1600SC Server
Dell PowerEdge 1600sc server is running
Please help me. Our Dell PowerEdge 1600sc server is running our services fine too, but lately we experience a low processing velocity on the net petitions. I have already defrag and clean all drives and uninstall some sofware, but it still woks slow.
We have grown at 43 stations. I can't find information about how many empleyees it soports and can connect to and use the resources. I'm worried because its my job.
bambinotti@hotmail.com
  • bambinotti Oct 15, 2008
    Sorry I forgot to say, system operating is Windows 2000 Advanced Server, doing service DHCP and Local Email only; 3 Shared Acces Databases. When restarted it processes correctly but after one or two hours it runs too slowly.
    Should I consider to install another server for 43 or more employees?
Cs_caca
Posted on Oct 22, 2008
  • 14 Answers
What operating system is the server using? What roles is the server doing (DNS/DHCP/DC/Exchange/etc). If it's a Windows 2003 SBS box, you're supposed to be able to run upto about 75 users. I would never run more than 30 users on an SBS box (and it'd have to be a very high spec). You may consdier bringing another server to do an aditional role (file/print) and leave the primary to be an SBS box
Posted on Oct 13, 2008
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
I am getting a loud beeping sound from the back of my Dell Poweredge 1600SC Server this morning. It seems to be operating fine, and there are no warnings on the computer. It IS very dusty inside, though....
The sound may be an indicator alert. overheating, unlocked latch, etc. If the system is running ok and no noticable problems with your software, check your BIOS setting for log information related to alerts. If you find nothing of significate problems, you can disable alerts in the BIOS.
Hope this helps. Good Luck
C2Solutions
Jan 18, 2011 | Dell PowerEdge 1600SC Server
No power to dell poweredge 1600sc. Redundant power supplies have no lights.
Either the power supplies have both failed, which is unlikely, or they are not connected to a hot outlet. Frequently servers are connected to uninterruptible power supplies (UPS) instead of being connected directly to a wall outlet. Make sure the UPS is on and functioning.
Dell provides lifetime phone support for their servers so you should give them a call if you need more help tracking down the problem. (800) 945-3355
If this helps please vote for my solution.
Feb 12, 2010 | Dell PowerEdge 1600SC Server
My Dell powerEdge 1600SC Server Fail.....
Sounds like you're running Windows Server 2003 and want to run a backup utility.
Fortunately, this OS ships with a built-in backup utility called we call "ntbackup."
You can launch this program from Start -> Run, or you can find it in Start -> Accessories -> System Tools -> Backup.
Jan 03, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
Can not access bois
It hangs there probably becuase one or more of the drives are dead or are almost there. Check and see the lights on the drives are falshing funny or too long or are yellow. If you find one of them that are that way, pull it out and then reboot.
See if that helps.
Nov 07, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
