Connecting sata11 hard drive - Computers & Internet
  • 1,124 Answers
Go to your bios and ENABLE sata.
Then go to your motherboard and connect your drive using the SATA cables on the right port.
See your motherboard chart
Posted on Oct 10, 2008
  • Pablo Csaky
    Pablo Csaky Oct 10, 2008
    The only difference you'll see in the SATA drive is the connector scheme (and the absence of drive jumpers).
    The host PC requires a SATA controller with one or more SATA ports, such as the Promise Technology SATA150 TX2plus, which combines two independent SATA ports and one Ultra ATA port and supports up to two serial and two Ultra ATA drives. In new SATA-compatible machines, the motherboard uses a controller chip that supports SATA.
    You'll also need new cables. Some SATA drives use different power cables and all use different signal cables, so you may not be able to use the traditional 4-pin power connectors. Serial ATA drives require power connectors with , , and .3 volts. Current 4-pin ATX-type power supplies provide only drive power connectors with the traditional and volt signals. This means your PC may need a power supply fitted with SATA drive power connectors or an adapter.
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
Kya hard drive ki storej disk ko kisi other hard disk me laga ke use kar saktey hai ki nhi
internal hard drives are now SATA connected ( you can get converted cables to connect older units) or external hard drives are usb connected
dless of the make you have , all hard drives will fit
Dec 30, 2016 | Hitachi Computers & Internet
How do i format a sata11 hard for use in another pc in windows xp pro 32 bit
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
hope this helps
Jul 12, 2012 | Western Digital Caviar Computers &...
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
My hard drive isn't being recognised by my laptop and is making an intermittent buzzing noise? I have tried both the power connection and the USB connection neither are loose.
did it come with a cd? if so, did you install the drivers for your Hard drive first before connecting? disconnect your drive, go the the hard drive makers website and download the latest drivers for the model of your hard drive. then re-connect your drive. hope that works =]
Mar 19, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I need to run an HDD2159 external of its computer.
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Oct 02, 2009 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
Power light panel on but no loading.sata11 asrock ddr800 ALIVE NF7G-FULLHD.walang response when you on the power but light front panel light up.
u must replace your processor only if u not hearing anytype of beep sound from pc. if u hear beep sound than u must replace ram of your pc.enjoy good luck plz vote on my comments
Sep 03, 2009 | Computers & Internet
320gb sata11 is not seen by bios
I have you tired using a different SATA connector or even SATA power connector, try and see if this helps...
Jun 12, 2009 | Computers & Internet
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
