Question about Graco Quattro Tour Travel System
Hi my wheel fell off, the plastic which connects the wheel to frame has snapped can i get a replacment.
  • 2 more comments
  • dawn968 Oct 10, 2008
    thanks, i tried looking for a factory on the net, have you got any more info?
  • dawn968 Oct 11, 2008
    thank you so much, that'l be a great help. ;)
  • Anonymous Oct 14, 2008
    hi my wheel also fell off at the same spot
  • chierons Oct 24, 2008
    hi i have the same problem where do you get a spare
  • 69 Answers
Yeah from the factory you can
Posted on Oct 10, 2008
  • Erick Beckwith Oct 10, 2008
    I will find the contact info for you :)
How to replace drivers side window on 95 chevy truck
Remove interior door trim. There will be screws as well as plastic pins that have to be pried out. Wind the window all the way down. There will be some tracks in the lift mechanism with rollers that are attached to the window frame. Locate and remove the bolts that secure the frame. The window should then come out.
Mar 05, 2015 | Cars & Trucks
Mothercare spin
Hi Stacey
Pop into your local Mothercare store or contact their customer care team for assistance.
Nov 26, 2013 | Baby Gear
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Wheel snapped off gracco pushchair
    I have the same problem on both front wheels of a Graco pushchair I inherited. I took the wheel assembly off and had a friend weld steel washers onto the end of the frame and then I pushed the barbed plastic pivot in. It worked for a bit but damage to the plastic barb causes the wheel assembly to fall off without much encouragement. Now looking for Plan B. It may involve more welding and modifications. Not sure what Graco parts cost but would imaging getting them to South Africa where I live would be prohibitively expensive. – MH
    Aug 29, 2010 | Graco Quattro Tour Travel System
    Headlight bulb replacement for 2007 saturn outlook?
    To replace a headlamp on a Saturn Outlook you need to access it via the wheel well. So jack up the car and remove the front tire. You'll see a collection of phillips head trim screws and plastic snap in panel connectors holding the plastic wheel well in place. Remove the screws and snap in connectors. To remove the connectors, pry the center button up with a small screwdriver. One it's up the whole connector should pop free.
    Remove the wheel well.
    Turn the black plastic cap on the back of the headlamp assembly 1/4 turn counterclockwise and it should come free. Now the lamp wiring and connector should be visible. Turn the lamp ~90 degrees and it should pop free. Test the bulb. More people have problems with the wiring connection and the bulb is usually OK.
    Aug 21, 2010 | 2007 Saturn Outlook
    The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
    I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
    Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
    It has been awhile since i removed my water pad and forgot how to route water line in pad
    I've got a 560A, but if it's similar:  The pad sits in a plastic frame with the drain hole and "funnel" at the bottom.  At the top of the frame, there's a plastic piece that sits at the top of the pad; it snaps into the frame and the frame snaps into the humidifier housing.  The water tube from the solenoid slides into this plastic piece so that the water is directed to the top of the pad.
    Dec 10, 2008 | Aprilaire 550 Humidifier
    Repalce Door handle on GE Profile model number SCA1000DBB03
    There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
    P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
    Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Need straps
    try REI or other camping store.
    Aug 14, 2008 | Baby Trend Snap-N-Go LX Double Stroller
    Graco Quattro Tour Travel System Logo
    220 people viewed this question
    Top Graco Baby Gear Experts
    Iron
    Iron
    kenneth njonjo
    Colin Stickland
    Colin Stickland
    Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
