Question about Canon PowerShot SD850 IS Digital Camera
Camera wont turn on or off
Ive had my SD850 for a little over a year now. i've dropped it a few times but its never been in water or touched water and its always seemed to work fine. it was working fine this morning, and all of a sudden this afternoon the power button stopped working--i'd have to press it a lot of times for it to turn on, and then i had to do the same to turn it off. i'd even take out the battery and put it back in and it would still be on. now it wont even turn on at all. my battery's charged and working, and its clean and everything. everything else besides the power button works fine..
  • 489 Answers
Hi
Sounds like the power button switch as been damaged... if I recall correctly it's a very small button and even a small amount of damage to it will cause the parts to no longer align properly which will result in the outer button that you push not reaching the inner button on the board of the camera.
One solution would be to open the camera and see if you can see anything obviously wrong with the button on the inside of the camera. The button is part of the flash assembly, so if there is damage to it replacing the flash will probably solve all your power issues!
If we can help with the part or do the repair for you, please let us know! We pride ourselves in AFFORDABLE digital camera repair... watch out for those ... 'geeks' they will want $150-200 to repair this problem as all they will do is send it to Canon and they will repair it for a flat rate of about $120+.
If all you need is the flash, I can get you one, new or used. New will probably be $40, used $25. If you want us to install it, the cost would only be the cost of the part plus $25 for the installation and return shipping.
Good luck with your repair, and even if you don't need parts from us please let me know if you need any more assistance.
Darntoothysam com
Thomas
Posted on Oct 10, 2008
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
My ipod touch wont turn on?
ive got the same problem so if u find out will u let me know how to fix it id greatly appreciate it thnx
Dec 30, 2011 | Apple iPod touch
My Canon PowerShot SD850 IS has a lens that is stuck in the extended position. I get a screen that says lens error, restart camera, but when I try to connect to the software, I get a screen on the computer...
Don't play around with that lens, you can do more damage to the camera and focus with some of the stuff people tell you to try. Your camera just needs to be serviced and you'll be working great again. The shop that specializes in service for the powershots is: camerasandparts.com They're amazing if you need a hand with one of these, that's all they deal with. They have your exact SD850 Lens Error, Restart Camera problem on their site. Good luck, they're the place for help with a powershot, best of luck with it.
Jun 23, 2010 | Canon PowerShot SD850 IS Digital Camera
My SD850 Canon says Lens Error restart camera. I have tried to turn it on/off numerous times taken out the battery and sd card. Is there anything else I can try
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 12, 2010 | Canon PowerShot SD850 IS Digital Camera
Drop GE A1230 digital camera in water. Let dry and now wont power
Unfortunately, there are several parts that may be damaged with water. It doesn't matter if it's already dry. Water contains lots of minerals and other material that are conductive. Once the water evaporated, the conductive materials stays in the electronics.
As you have a broken camera anyway, you can try:
* Using a hair dryer, blow some hot air (no the hottest level) inside the camera. protect display away from the heat.
* Get a new camera to replace the damaged one.
Sorry Ricky, I don't think it can be fixed.
Aug 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
My canon SD850 IS digital camera is not even a year old and well taken care of. I thasnt been dropped and is already broken? What do i do...everytime i turn it on all of the sudden the lense is stuck poped...
Take a look at the suggestions at the top of page 122 of the Advanced Camera User Guide. The suggestion is that the cause may have been that the camera was still on when the memory card/battery cover was opened. Try closing the cover and then turning the camera off and then on again. Hope this helps.
Jack
Nov 26, 2008 | Canon PowerShot SD850 IS Digital Camera
Pictures ive taken on my refurbished sd850 are blurry
it might be because your camera moved while you were taking pictures or try cleaning the lens...
Aug 03, 2008 | Canon Cameras
Canon PowerShot® SD850 IS
Hi
what you are seeing is a generic message that means there is some sort of problem with the lens, it could happen in many different ways such as sand or dirt in the lens gears.
If your camera is less than a year old, please call Canon and have them fix it under warranty!
If your camera is more than a year old and out of warranty, a couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon for repair out of warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam com, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We have your repair listed as a package in our store for about $70. This covers a new lens, and return shipping of your camera! We even give a 45 day warranty on parts and labor. If you think you can use us then please check us out, even if you need to ask more questions then please feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
Mar 30, 2008 | Canon PowerShot SD850 IS Digital Camera
Well I dropped my Canon PowerShot® SD850 IS on the bathroom floor!
You need to take it to a camera shop for servicing, this is not something you're going to be able to solve at home
Mar 20, 2008 | Canon PowerShot SD850 IS Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
