AdSubtract Pro I get message that I have a buffer overrunn caused by AdSubtract. As a result my IE won't open a webpage.
  • 7 more comments
  • gumbasub Oct 11, 2008
    "buffer overrun detected" this shuts down adsubtract
  • Anonymous Oct 12, 2008
    Appears to be the same. MS Visual C++ Runtime Library, Buffer Overrun, in AdSubtract, AdSub.exe. First occured 10/11/08 after successfully visiting a particular commercial web site. Buffer overrun error now occurs shortly after reboot, even without opening IE.
  • Dancing Chef Oct 12, 2008
    My problem is exactly the same. I have adsubtract on 3 computers, a laptop, and 2 desktops. Buffer overrun appears when booting, and intermitanly when attempting to use the program.
  • c_nye99 Oct 12, 2008
    I also had the same problem starting October 9, 2008. Fortunately I found this site through Google and have applied the fix as described by Clif4949. It works perfectly now. Thank you, thank you, thank you. Additional note: when I finally figured out that AdSubtract was the reason I couldn't access the internet, (I had received the "buffer overrun detected" warning) and I had clicked OK on that window. Finally, I just ignored the warning and left it on screen (its window [Microsoft Visual C++ Runtime Library] still open but behind other windows). Then I was able to access the internet normally, except for the annoying extra work of dealing with the alarm. Clif4949 is to be thanked again. Yeah!
  • EdiburghFixr Oct 12, 2008
    I had exactly the same problem, but your Best Solution has fixed it for me too. Very many thanks, becuase AdSubtract Pro is an excellent program that does exactly what I want.
    James
    I had the same problem. So did my husband. We knew it had to be something trend micro did since it happened on both computers. I tried everything to fix it. I emailed trend micro and they sent me directions on how to delete it, instead of fixing it. I tried myself first to uninstall it, but then I couldn't connect to explorer at all. I was able to connect with aol and firefox but not IE. I had to reinstall it to get online. Fortunately I I found your solution here and tried it, and hooray it worked. Thanks so much.....I loved the program and hated to have to give it up...those sneaks...you'd think they would have told me in their email instead of jerking me around. Thanks so much.
    Barb
  • cds245 Oct 13, 2008
    Thanks to "Best Solutions." You solved my problem with AdSubtract Pro. I did not
    want to give up using the program; it is really a nifty one. Thanks also for getting
    back to me so promptly with the solution.
  • Anonymous Oct 13, 2008
    Thanx so much Cliff4949. I had the same headache for the past few days and assumed that it was due to my isp. I spoke to them and had a service tech come to the house. Did a System Restore and removed the program. I was all ready to download another pop-up blocker program. Finally I googled "AdSubtract buffer overrun" and found you. Your resolution worked perfectly.
  • Anonymous Dec 17, 2008
    I have the burrer overrun by adsubtract, How do I fix it?
    Problem Solver:
  • 5 Answers
Adsubtract "phones home" everytime it is started. it looks to intermute.com which then refers to store.trendmicro.com (the purchaser of intermute). trendmicro recently changed their website to disable adsubtract (either wittingly or unwittingly)
Here is how to fix:
1) first find your hosts file. it is usually located in C:\windows\system32\drivers\etc
the file is "hosts" and it has no file extension.
2) open the hosts file with notepad.
3) add the following line to the bottom: 127.0.0.1 store.trendmicro.com
Adsubtract will work once again if you follow these instructions, but you will no longer be able to visit the website "store.trendmicro.com" unless you change your hosts file back the way it was.
contact:disposable4949 at gmail dot com
Posted on Oct 12, 2008
Posted on Oct 17, 2008
I have an older PC with: ie 8 that has been updated by microsoft, and now seems to be getting to slow...My internet security keeps giving me messages that Ie is taking up alot of memory. I already added...
There is a memory leak in IE8 that MS won't admit to, but many pro's have reported. I would suggest you install Google Chrome, Firefox or Opera, and use one of them as your default browser, opening IE8 only when absolutely necessary (some sites won't work with anything but IE).
There's really not much else that can be done...except to wait for MS to admit the problem, and issue a patch to correct it. And, given their whittling away of support for XP, I'm not holding my breath.
Jul 04, 2011 | Microsoft Internet Explorer 8
Tip
3 Quick Solutions to Repair Juno Webmail Script Error message
If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
    1.Add Juno Mail to the exclusion list of your ad-blocker
    2.Set up the ad-blocker to enable banner ads
    3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
    Solution 1 - Insert the Juno Webmail to the Bypass Site list
    If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
    Solution 2: Configure AdSubtract to enable banner ads
    This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
      1.Launch the AdSubtract program and click on the 'Block' icon.
      2.Deselect the Banner Ads field from the selection on the left.
      3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
      Solution 3: Disable AdSubtract tool filtering
      This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
        1.Launch the AdSubtract tool.
        2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
        3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
Juno Customer Support Phone Number
on Apr 11, 2017 | Miscellaneous
Tip
Convert Stubborn Webpage to pdf...
I have come across some websites that I wanted to save the page for later review. I found that I was having some problems with certain sites. I found a ways around it.
What you need:adobe acrobat pro (latest version) or better popupcop.
There may be a simpler way to do this but if found that this works:
When at a webpage that you want to copy (YOU MUST BE USING IE AND HAVE BOTH POPUPCOP INSTALLED AND ADOBE ACROBAT PRO OR HIGHER, CONVERT TO .PFG), slide popupcop popup intensify bar to the far left, now click on adobe acrobat icon to convert webpage to .pdf document. I have yet to find a webpage where this trick does not work.
I't might help you a lot. Good luck!
on Jan 18, 2010 | Computers & Internet
1st: can't open gmail w ie; 2nd ie keeps shutting down
Hi, It seems that you might have installed some addons for IE and now you are in the situation. All you need to do it open Internet Options from Control Panel. Then in Advanced tab, click on Reset. Resetting Internet Explorer resets all settings to manufactures' default and in the process you will lose all saved passwords on Internet Explorer and you will have to re-enter them again upon use. Once done, fire-up IE and click on Tools menu > Internet Options and reset IE from Advanced tab once again from here as well. It means you will reset IE two times, first from Control Panel and then from IE window itself. Once done try to use IE and see the result.
However there are few addons available with Mozilla Firefox that resembles IE inside and opens all webpages that requires IE only. Download Coral IE Tab from: https://addons.mozilla.org/en-US/firefox/addon/10909
Installed the addons and switch the view to IE to open all webpages that supports IE only.
Cheers!
Mar 02, 2010 | Computers & Internet
Internet explorer cannot display webpage
what version of IE are you running, ver8 has a reset button in the tools, options menu
or it could be a bug affecting IE
Dec 20, 2009 | Microsoft Computers & Internet
AdSubtract Pro - Activate after re-installation
have emule or similar?
this is a key generator. Linking to it is legal, downloading might not be. I'm not sure. Anyway here's the link:
ed2k://|file|Adsubtract%20Pro%20v3.06%20(C)%20Intermute%20Incl%20Keygen-Ror%20Shareconnector.rar|2153402|B3B39992AC3D20410F7F7910C3220BA1|/
Oct 22, 2008 | Computers & Internet
Buffer overrun in adsubtract pro
From IE toolbar, click tools, internet options. Then click the connections tab. Click lan settings button. uncheck the radio box that says Use a proxy server.
IE will work again, but with no adsubtract. A possible reason the fix didn't immediately work for you is that the dns cache needed to be flushed. accomplish this by clicking start, run, cmd.
in the black box, type ipconfig /flushdns
then press enter.
Oct 18, 2008 | Computers & Internet
Leave comment
If it was a chat you can login to your Fixya account then go to My Profile then go to Live chats then select write a comment. If it was a question like this you can go to My profile then you can see your questions there. Select the question then you can leave a comment.
Oct 12, 2008 | Computers & Internet
Reg : Navigation to the WEBPAGE is cancelled
right click to internet explorer and select properties and goto advanced tab and then select restore defaults and then close the internet explorer and then open the IE
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
633 people viewed this question
David Payne
David Payne
