Question about Thermador MBBS Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
18 month old Thermador MBBS 1100 Watt Microwave- very clean inside.Last night I used the microwave to warm some butter (10 seconds). When I opened the door I was overcome with the smell of something burning and smoke coming from the right side of the microwave. It appeared to be coming from the light but I can not be certain. I am now scared to use the microwave.
  • tullyreb Oct 14, 2008
    I took the wave guide cover off. It looks like new on both sides...no burns or grease. Can the mica cover burn without showing any signs of actaully burning?
    The microwave cooks very well.
  • 99 Answers
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Posted on Oct 11, 2008
  • Reg Woolley
    Reg Woolley Oct 14, 2008
    Does the Mic. still work ie. cook anything?If not could it be rectifyer gone these can smell bad.
    dont forget microwaves gan give you a shock even when unplugged
  • Reg Woolley
    Reg Woolley Oct 15, 2008
    Sorry have got no more help for you,Would need to inspect microwave.Why not take to repair man,Some will look for a small estimate charge.We do.Grandadfixer.
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Sep 16, 2009 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Thermador Built-In Microwave MBBS/01 Diminished Power
Smell could indicate burnt rectifier or mag. ( Or Both) Even a partially shorting transformer that hasnt yet fully shorted out and blown your fuse. I do not know that unit, but if it would happen to have 2 mag systems you could lose 1 and it still heat but probably only at around half power. It has been a long while since I have had to work on a Thermadore. But last time I did I rememeber most of their parts distributors I used to work with had all closed. Do you still have a manuel for that unit from when you purchased it?? Try to find a contact phone number to see if you can call thermador. Ask them if they have anyone in your area doing service for them. While it may no longer be under warranty, a servicer who represents them will have parts, or acces to parts and service literature that other servicers will not.
Aug 16, 2017 | Thermador MBBS Microwave Oven
I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
Nov 27, 2008 | Thermador MBBS Microwave Oven
Thermador MBBS Microwave Oven Logo
399 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
