Question about BenQ MP770 DLP Projector
Vertical parallel lines across the screen, sometimes they disappear after a while or sometimes not.
When the projector (bought April 07 but low useage - every couple of weeks for a few hours) is first powered up, thin parallel vertical lines appear across the screen. They're black but seem to have little flashing lights too. No other indicator lights (like the lamp or the temp) are on, so don't think it's the bulb. The first time it happened they disappeared after about 15 mins. The second time, still there after an hour. Tonight, they disappeared when I turned it off and back on. Any ideas anyone? Thanks.
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve
Posted on Jul 02, 2008
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
Marrie
  • 563 Answers
SOURCE: Thin vertical line appears on projector
Hi Martin103
This is a typical BenQ Mp Series problem , and will notice that it will start of intermittently , but later on the white line will appear every single time.
This can only be fixed by replacing the Mainboard of the MP710/720/721
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
xptareq2000
  • 1447 Answers
SOURCE: Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Posted on Dec 13, 2009
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
BenQ MP770 DLP Projector Logo
69 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
