Question about Sony Playstation 3 (PS3) Console
Ps3 hdmi hi there . i got a ps3 and originally ran it through a component cable however i have just purchased a 1080p tv and tried to use a hdmi cable and nothing happens i put the other cable back in and changed the settings but it just goes back to the one under hdmi i have also tried the power button trick would be gratefull for any help
  • 344 Answers
Hello. No offense to you but many people do not do the video reset properly. Here are the official Sony directions.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine
If that doesn't work I would reformat your system. (If you don't have a lot saved on your hard drive that can't be replaced) But there are many options under the system setting folder that you can reset or reformat. Other then that I have no idea. Maybe the video port is shorting out.
Hope this helps. Good luck and happy gaming!!
Posted on Oct 10, 2008
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 Flickers when set to 1080P on 32LG70
This may help... open Display settings, scroll down to the Deep Color option... switch it from automatic to off. So far this is the only solution that I have found
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
1080p high def issues
The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
Mar 29, 2008 | Televison & Video
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
