Question about MSI 915P Neo2 Platinum Motherboard
Motherboard problem! Hello everyone. I am using a MSI 915P Neo2 Platinum Motherboard. I tried reformatting my PC. But whenever I install my Windows XP, a blue error screen appears and says that something in my hard drive is wrong. I have changed my hard drive two times already. Also used 2 different CDs of Windows XP. Help. I really don't know what to do. Thanks in advance.
  • zakstreon Oct 12, 2008
    Hi there rehortonjr. Thanks for the help.
    I have managed to skip the blue screen error thing when installing Windows XP. It seems that there were problems in the BIOS and in the cable. It is okay now.
    But I now have a new problem. Whenever I try to install Windows XP, i receive an error and it says,
    FATAL ERROR:
    An error has been encountered the prevents Setup from continuing.
    One of the components that Windows needs to continue setup could not be installed.
    A component's file does not match the verification information present in the component manifest.
    ERROR:
    SXS.DLL: Syntax error in manifest or policy file 'D:\I386..."
    That is the error I am receiving. Help please.
    Scholar:
  • 47 Answers
Hi!
An error message like this can mean a lot of different things, unfortunately. Should you get the message again, please write it down verbatim, as that would help a lot in diagnosing your problem.
A good starting point would be to make sure that all your BIOS settings are correct, especially those that relate to your hard drive (things like RAID/No RAID, auto-detect, IDE/SATA, on-board device settings, etc.). If you do not know what a setting should be, I'd refer to a website like www.tomshardware.com or www.overclockers.com for reference.
The next thing to do would be to get a known good stick of memory from another machine that is working fine, or if you can't do that, buy a small stick of new memory to act as a test device (there is also software that you can find on the Internet (like memtest) that will check out your memory for you, but those tests are not foolproof). Try installing XP with just that one stick of memory and see if you can complete the installation. If so, then your at least some of your original memory is bad.
Assuming that it is not likely that 2 hard drives and 2 copies of XP are bad, if the culprit is not the memory then there are only 3 things left that are likely to be the problem: 1) Your power supply (I keep a good power supply on hand as a spare for these situations, since you can get a 450-500 watt unit for $30 on sale) 2) Your processor (not likely, given your description) or 3) A defective motherboard. If you do all the things I've described and still have the problem, I would advise you to document all your troubleshooting steps thoroughly and then contact MSI. My experience is that they will RMA the MB if it is still under warranty.
Good luck. Please let me know if this helps. A rating would be appreciated if you deem it appropriate.
Bob
Posted on Oct 10, 2008
  • Robert Horton
    Robert Horton Oct 14, 2008
    Hi Zakstreon,
    Once again, you have a problem that is darn near impossible to resolve without having the machine in front of me :(.
    Microsoft's position is that you have a defective XP installation disk. I'd flip the disk over and look carefully for any scratches, fingerprints, or dirty spots. Sometimes scratched disks can be at least temporarily repaired by rubbing "with" the scratch repeatedly with a moist, soft cloth. I've also found that sometimes you can make a copy of a disk that won't install but the copy will work (the copying SW is what allows this to happen; I won't bore you with how!).
    Here's Microsoft's cleaning recommendation:
    Examine the Windows XP CD and make sure it is absolutely "pristine clean"
    with no scratches, fingerprints or smudges. Use a mild non-ammonia based
    household cleaning solution and a soft cloth to clean it.
    "Manifest Parse Invalid at the Top Level of the Document" Error Message When
    You Try to Install Windows XP
    http://support.microsoft.com/defaul...1&...
    Finally, make sure that you are using a legitimate copy of XP. If you still have access to two copies of XP, try them both. Also, don't forget that a slightly malfunctioning memory stick can cause problems just like this,
    Good luck, and please let me know what happens!
    Bob
Hi i have a desktop computer motherboard neo2 915G with dvd rw-dl ND-4570A. I am trying to install windows xp. Just before it reboots it always goes into the fatal blue screen contact admin etc etc. I...
Have you tried booting in to "Safe Mode", your Blue Screen could be caused by wrong driver or other hardware issue...Booting into "Safe Mode" will load minimal drivers hopefully bypassing your problem.
The Blue screen also display code that can help you troubleshoot your problem, this info is displayed near the bottom of the screen...
Feb 22, 2011 | MSI 915P NEO 2 PLATINUM INTEL 915P CHIPSET...
Laptop will turn on, but can't load recovery or driver disks and if i don't use those i get a disk read error press control alt delete.
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 29, 2010 | MSI 915P Neo2 Platinum Motherboard
IC7-Max3 with 2x512Mb OCZ PC4000 memory sticks (184 pin DIMM). Only registered 512 Mb. Vacuumed dust and cleaned. Now won't post. Cleaned memory sticks with eraser. No beep. Recovery path?
vacuums can cause static electricity. this may have damaged your motherboard in some way. you have to use a special anti-static vacuum when cleaning electronics.
Dec 26, 2009 | MSI 915P Neo2 Platinum Motherboard
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
What is the socket for this motherboard and what cpu's can i use in it
http://global.msi.com.tw/index.php?func=cpuform will tell you but is the board revision a or 1.0b? Get that off the board itself and you are away.
Jul 05, 2008 | Computers & Internet
Installing new ram...wont work
Go HERE for troubleshooting guide. Scroll down to: Stability Problems - Memory Issues.
Jun 03, 2008 | MSI 915P Neo2 Platinum Motherboard
Front panel connections
The manual shows the correct pin outs, and can be downloaded here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=585
Jan 26, 2008 | MSI 915P Neo2 Platinum Motherboard
Beep sounds and their meaning
Hi All PC do what is called a POST a Power On Self Test and emit different beeps according to the make and model of the BIOS loaded. You can check out what they mean for different BIOSes here http://www.xmission.com/~comphope/beep.htm. This site lists the different post codes etc by the different bioses. So you will need to know what BIOS your PC is running just check the black screen at starup before any windows info comes up and look for something like AMIBIOS or AWARD etc, you can pause the screen so that you can read it more easily by pressing the pause button on your keyboard, this is normally the last key on the top row on the right. Hope that helps
Sep 04, 2006 | MSI 915P Neo2 Platinum Motherboard
MSI 915P Neo2 Platinum Motherboard Logo
118 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
