OVERHEATS - Heating & Cooling
What kind of a ********* question is this? what over heats? the outdoor motor? the indoor motor? the compressor? the breaker for the airhandler? thebreaker for tha condensor? be specific and detailed in your questions and you'll get a specific and detailed answer. with a question like it overheats you'll get an answer like spray water on it....... try again with a little more effort please.
Posted on Oct 11, 2008
Outdoor unit overheats
Clean the condenser & check the Freon levels
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
Overheats.car runs rough,fuel smell in antifreeze and oil.1995 bmw 740 i
your thermostat might be faulty,,thus playing up with your cooling and heating system,,replace thermostat
Dec 04, 2012 | BMW 1995 740 i
My split ac unit compressor is cooling but then it overheats and trips off
check the freon is ok though unfortunately the compressor does not have much life yet
Apr 12, 2012 | Heating & Cooling
My intertherm central ac is running short cycles
Hi!!
It most likely mean that the condenser needs to be cleaned up.
At hardware stores and A/C shops, they sell a cleaner for it, get the ECO frienly version. Instruccions are in the bottle.
If condenser looks clean, (that you can see thru it), then check fan motor, it could be going bad not giving the right RPMs. When this happens, it overheats.
If the condenser can't get rid of the heat the evaporator picks up, the compressor overheats and the thermal proteccion device kicks in to protect it from getting damaged..
Don't forget to rate this post!! Good Luck!!
Jul 25, 2010 | Intertherm Heating & Cooling
Panasonic split system fan motor overheas
put the lubricants or grease motor bearings
Oct 10, 2009 | Heating & Cooling
Central air unit condenser fan overheats and shuts the unit outside.
replace the capacitor first but most likely the windings in the fan motor are burning up if there is a oil port on the motor add some but i think you will just need to replace motor hope this helps
Sep 29, 2009 | Heating & Cooling
My motor switches from high to low over and over again
It sound like the low speed winding in the motor is bad.You will need to get a new motor.
Jul 24, 2009 | Mastercool 67680 Evaporative Cooler Air...
Dayton 1/2 hp dual voltage motor overheats (mtr #6k79). Replaced original motor with same motor overheats in 10 -30 minutes. White lead to #4 terminal, black lead to #1 terminal, ground to casing.
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Jul 23, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
