Question about Sony KP-65WV700 65" Rear Projection HDTV
Sony KP 65WV700 Help
Not too long ago I had a problem with this tv where a repairman came out due to a misalignment of the blue color. When looking at teh screen there was a blue halo to the right of most images. Apparently it was some IT chip that got replaced. Now the same thing seems to be happening to the magenta color. Can you tell me what part and how to repair this? I can't afford the $400 to 500 or more repair cost. I am very capable with a soldering irn and can read a multimeter.
  • ROCKY00723 Oct 12, 2008
    My Sony KP 65WV700 Tv is having a convergence problem with the Magenta color. Is this a difficult repair and are the parts very expensive.
    Thanks, Rocco
    Novelist:
    Champion:
  • 203 Answers
This sounds like you are having a convergence problem and the convergence IC's most likely need to be replaced. Is the repairmans warranty exprired?
If you would like to repair this yourself please email me so i can assist you, also please include a picture of what you are seeing on the screen as well as a couple of the cirucit boards inside the tv so I can make it easy on both of us.
Thanks
Tim Nolan
experttv@comcast.net
Posted on Oct 10, 2008
On my Sony KP-65WS510 The colors are misaligned in the picture and the picture is bowed. Any ideas? Thanks!
This problem appears due to convergence output ICs failure located on D board in tv. There are two big black ICs that need to be replaced, soldering work is required.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Nov 23, 2010 | Sony KP-65WS510 65" Rear Projection...
Blue screen for about a half hour and then still blueish color
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D look pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergencce picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
I need a blue picture tube re-necked / rebuilt
Go to the following link and leave your model number in a email and list which tube you need, they have access to just about any new replacement tube that you need for Sonys. they dont list them all, but leave a email I am sure they will have what you need.Heres the link.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-65WV700 65" Rear Projection HDTV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
