Question about Lands Phones
Phone says line in use but the phone is not being used
My phone line says it is in use but it isn't.
RCA Visys model #25424RE1 how do I setup voicemail
The 25424RE1 isn't a voicemail system. Please consult the documentation for whatever voicemail system you're using.
If you require further assistance, please repost your question specifying the voicemail system you're using.
Oct 19, 2012 | RCA ViSYS 2-Line Speakerphone
Network
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 02, 2012 | Samsung C6112 Cell Phone
My phone 660-2?
The Uniden D1660 isn't an answering machine. If you want to change the ring count, you'll have to do that on whatever answering machine you have connected to your phone line.
Jun 22, 2012 | Uniden Dect 6.0 Expandable 2-Handset...
How to hook up fax on HP C7280
The C7280 can be used as a stand-alone fax machine. All you need to hook up to the printer is a telephone line. Connect the phone line to the jack marked "1-Line" on the rear panel, below the power supply connector. If you want, you can connect an extension phone to the jack marked "2-Ext". The line connection is for a standard telephone line. Once the line is connected, faxing is pretty much the same as it is on any fax machine. Put your documents face up in the feeder on top, or for a single sheet, face down on the scanner glass. Press the "Fax menu" button on the control panel and you'll be asked for the number. Enter the number from the keypad and then press the "Start fax black" or "Start fax color" color button to send the fax. Other than the phone line, there isn't anything else you need to hook up.
You can download the manual from HP if you need it for reference. It explains how to use the special features of the fax machine, like broadcast faxing, memory dialing, printing fax reports, etc.
Aug 17, 2011 | HP Computers & Internet
I need to know how to check the voicemails
The 6041 isn't an answering machine. If you have an answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail service offered by your phone company, contact them for information.
If you need further assistance, please feel free to repost your question specifying the answering machine/voicemail service you're using.
Jun 22, 2011 | Vtech Cordless 6041 Phone
People can not hear me but i can hear them
Make sure that the phone isn't muted. There should be a button that looks like a microphone. If it's gray then the phone is muted. If it isn't, try using the camera or something to make sure your phone's microphone isn't broken.
May 04, 2011 | HTC Inspire 4G Smartphone
I cant set a voicemail on my phone
The 6041 isn't an answering machine. If you have an answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail service offered by your telephone company, contact them for information and assistance.
Apr 10, 2011 | Vtech Cordless 6041 Phone
I have a voice mail on my GE phone, but I forgot how to listen it.
The 25932 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribed to a voicemail system offered by your phone company, contact them for instructions.
Mar 03, 2011 | GE 25932 Cordless Phone
I am away from home & would like to retrieve my phone messages.
The 6041 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your phone company, contact them for information.
Feb 08, 2011 | Vtech Cordless 6041 Phone
Help me with setting up the answering machine
The LS6215 isn't an answering machine. If you have a separate answering machine connected to your phone line, refer to its documentation. If you subscribe to a voicemail system offered by your telephone company, contact them for instructions on setting up and using their system.
Nov 30, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Lands Phones Logo
143 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
