LG Corbel A- Accessory Range Hood
Problem for LG Corbel A- Accessory Range Hood
Help: LG Plasma display problem
By Rachel007 - usenet poster
I have had an LG plasma for about a year with out any problems. I turned it
on last night and it now has a black, vertical band 2" wide in the middle of
screen all sources/all inputs, all of the time. Anyone else had the same
problem or know if it is fixable?
Same Problem
Mar 05, 2009
-   hi,
i've got a LG plasma tv for about 3+ yrs. two nights ago i was a movie and suddenly the display gone blank. since then there's no power/display on the screen but can hear sounds. any suggestions would be greatly appreciated.
thanks
rana -   s rana
Feb 17, 2009
-   one black bar runs for 20minutes then a second black bar shows up on screen small lines on left side of screen green blue always their .does not have to heat up for these about very narrow lines 1in for all of them LG RU42PX10 -   Blueboy1
Dec 01, 2008
-   Hi
My philips plasma has just developed the same problem, being a 30mm vertical black line down the screen
Did you manage to resolve the problem
Best regards
Richard-   atlas_uk
Nov 27, 2008
-   Is it hot put a fan on it. If it is a matrix driver where are they fixed or can I do it?
-   Guest
Apr 16, 2008
-   Same problem. It started with one 2' vertical black line, but has progressed to two or three, intermittenlty on my hitachi 42' std def plasma screen. I phoned hitachi here in Sydney and they said they dont know what might be causing them, and that I should contact a service centre. I havn't done that yet.-   Matthewburns
Best Solution
posted on May 26, 2006
Very Helpful)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
You will have to get a tech to check it for you. He will have to be properly
equipped, and trained to work on the type of Plasma display you have.
Generally, the small shops will not be able to directly service it for you.
If it is more than a simple problem, they would have to jobber it out to an
authorized service centre.
If you contact the place where you bought it, or contact LG directly, they
can tell you who in your area can service it for you.
These displays are usually serviced at the modular level only. If it is the
main matrix driver board that is defective, this means that the Plasma
screen itself will have to be replaced. It is also possible that there is a
power supply fault with the unit.
The is why I tell people to buy an extended warranty with these expensive
displays. Many of them think that the vendor is only interested in some
extra money. But, the point is that the extended warranty is an insurance,
in case the unit fails. Repairs to the LCD and Plasma displays are generally
very expensive.
JANA
Was this helpful?
Yes
No
Solution #2
Very Helpful)
Powe33
Rank: Apprentice
Rating: 0%, 0 votes
You'll have to get it looked at by a tech. If it's under warranty then no
problem, otherwise there's a good chance the problem is one of the driver
boards which may be bonded to the panel in which case it's not repairable.
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2009
Not Rated)
diamongeezer
Rank: Apprentice
Rating: 0%, 0 votes
This is a problem with some soldered mounts of the surface mounted resistors on the ribbon cables running to the panel itself, you need to take the back off, remove stand, remove main processor circuit boards and resolder all the resistors. Not a job for the faint hearted.
Was this helpful?
Yes
No
Solution #4
posted on Aug 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
lg pc 55 now pic
Popular Solutions for LG Corbel A- Accessory Range
Questions and Unsolved Problems for LG Corbel A- Accessory Range
Do you recommend LG Corbel A- Accessory Range Hood?
Answer
Answer
I am connected via a cable box. Manual recording works fine but when setting up timer record it... (More)
Answer
My LG Range hood key pad is not working on many of the button including the vent.  Is there a... (More)
Answer
plasma screen is constantly flashing
Answer
whilst transporting the set i've ended up with a 'smudge' on the screen, it seems to be in between... (More)
Answer
i got no video but i have audio for an lg plasma
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 07, 2007
Exactly the same problem - vertical 2" bar in centre of screen. Have had the LG plasma TV for 3 years.
Describe your Kitchen Hoods problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Hood Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
