Posted on Oct 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP Photosmart C7280 I ran network configuration page and it says everything is ok. But I can't print anything off the internet How do I no if everything is connectd by the way I have a wireless router and it seems that it is connected to the printer I don;t no what to do can you help me please?
JDTec
Level 3:
  • Master 4,338 Answers
  • Posted on Oct 10, 2008
JDTec
Master
Level 3:
Answers
4338
Questions
0
Helped
2126952
Points
14653
Verify that the printer is getting a good IP address.
Then go to the Control Panel >printer and Faxes>click on your printer.
Then ports . There check to make sure that the printer is showing up next to the box that has the same IP address as your printer. If it does not , put a check mark in the box with the IP address. Then try to print a test page.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How do I print a Network Configuration Page on HP Photosmart C4150
have you plugged it into the network and ran a search on your Pc to recognize it?
HP Network configuration
first tell me the printer name?
2answers
How can I get the mac address for my printer ( HP PhotoSmart C4385 )
Look through the menus on the device for printing a "Network Configuration Page"
Look for "Hardware Address" on the page that prints out.
Hope this helps you!
Leave a rating if so!
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
4helpful
2answers
My C7280 HP photosmart will not scan to my computer.  I get the message "no scan options"
I have had a similar problem that appeared soon after an automatic HP software update over the internet. I solved the problem by uninstalling and reinstalling the HP software that came with the CD. I inserted the CD and ran the de-install for only the program that controlled print and scan and then re-installed the software for print and scan. Straight afterwards, the scanning started to work again
7helpful
3answers
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
k24674
ADMIN Andrew
ADMIN Andrew
