Question about Seagate Computers & Internet
Cant open the freeagent drive
I cant opnen da freeagent drive wem i click on it try to open it it says ""ERROR LOADING LIBRARY...."C:/WINDOWS/CEEDO/INSTALLER/BRAND.DLL
nd another message under dis one says....
   "the specified module could not be found"....
thank u..
laine
  • Gallo44 Mar 26, 2009
    My error message reads
    Error loading library:
    C:\Users\Marty\AppData\Local\Temp\Ceedo\Installer\Brand.dll.
    The specified module could not be found.
    Master:
  • 538 Answers
Sounds like you need to re install the drivers
Posted on Oct 13, 2008
Drive windows format
ignore the format thing, totally.
its MS way of telling you , its seems corrupted.
what system? PC, dvr, MAC, laptop.
what OS, windozs what,? xp,w7.w8?
the FreeAgent is and external HDD.
1: is the power pack plugged in?
2:is the led indicator dead on HDD.
3: did you try all USB ports.
4: did you try it on another system.? and USB port?
5: did you look in disk manager to see if it shows up, say DISK2?
6: did you ever drop it?
Oct 05, 2013 | Seagate 500GB FreeAgent GoFlex Hard Drive
I want to use my seagate 500gb freeagent to store movies and to play them on the tv, but when i load movies on to it, it comes up as an unsupported device. i cant open it up at all. thanks.
The video you want to play must be in the correct format and your tv must be USB compatible to read off of the usb.
If you have an Xbox, or Wii and put XBMC on it, it should be able to play various video types such as .avi, .mov, and etc.
Mar 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
250 gb seagate external hard drive is recognised b the computer but doest open. when open command given, error message comes 'i/o error' please help me
Sounds like the drive is dying. Your only hope might be to try a scandisk and defrag. From My Computer, right click on the drive and go to Properties. Select the Tools tab. Run the Error-Checking tool and make sure all check boxes are selected. Once that finishes, run a defrag from the same menu. If those don't work, the drive is likely done. Sorry.
Feb 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I cannot access files on a Seagate FreeAgent 320 GB external drive. My Windows XP can see the drive; and can see the basic file/folder directory structure, but I'm not able to access or open any of the...
Open "My Computer".
Right-mouse click on the drive-letter for the drive.
Click Properties.
Click Tools.
Click Check for errors (in the "file-structure").
Click to allow it to "fix" errors.
Dec 08, 2009 | Office Equipment & Supplies
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a 500 GB Seagate Freeagent Pro Ext Hard Drive (USB). The hard drive is appearing in My Computer. But the Icon is not the one that should be appearing. When I click on the drive, the drive does not...
The autorun file in the drive has been modified. A virus should have done that and in turn your anitvirus must have found and removed the virus. Hence windows is now trying to find the missing application. You can revert this by either removing the autorun file in the root folder, or by modifying it to your liking. If you need further assistance, comment back.
Jul 28, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Trying to format for MAC
I had a similar issue and was able to work around it by partitioning the drive. See this site for information: http://www.kenstone.net/fcp_homepage/partitioning_tiger.html
Overview: Open Disk Utility, Click on the Drive, Click Partition, Choose the number of partitions, and click Apply.
(It's written for video editors, but is applicable in your situation)
Let me know if this helps!
Apr 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
886 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
