Question about Plumbing
Need to find information on gate valves
I am a college student and currently learning on how a cast iron gate valve works i need diagrams to print off for my portfolio and to learn how to take one apart and how to maintain a gate valve i would be greatful for any information thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi robert garet,
I'm Harvey the Master Plumber.
Your problem is: You are a college student and currently learning on how a cast iron gate valve works you need diagrams to print off for my portfolio and to learn how to take one apart and how to maintain a gate valve you would be greatful for any information thanks
For small valves, it's just a mater of unscrewing the bonnet (top part with handle), with larger valves, you remove the bolts around the bonnet. Always turn off the pressure in the line before maintenance. If there's a leak where the shaft comes out of the bonnet then you need to replace the packing material inside the bonnet. This is usually a good time to put some apropriate lubricant on the threads at the botom of the shaft. That's about it from a practical point. I don't happen to have any pictures but you can take them yourself at any plumbing supply or they might let you fotocopy the expanded pictures in their parts book. They're usually happy to oblige.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
I have a 1992 rodeo 3.1 liter with. Broke alternator bracket and can not find one anywhere !!! What else can I use
92 getting back a bit ..yes might be a hard thing to source
.may have to go across states ......it is postable .
a wrecker or junk yard ..private one being parted out
..ebay if lucky
aluminum ..can it be welded ?
is it an upper and lower bracket or a one piece ?
Oct 19, 2016 | Cars & Trucks
What arm the specs for 95 camaro lt1 350
Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal link
Intake and Fuel Delivery
Fuel Delivery: Electronic Fuel Injection, sequential port
Injector Size: (17124248) 3.0gps, 22lbs/hr speed density (1992-1993), 24lbs/hr mass airflow (1994-1997)
Throttle Body: 48 millimeter twin butterfly
Intake Manifold: (12552137) Aluminum
Factory Power Ratings
92-96 LT1 Corvette: 300bhp, 330lb-ft
1996 LT4 Corvette: 330bhp, 340lb-ft
1992 LT5 Corvette: 375bhp, 370lb-ft
93-95 LT5 Corvette: 405bhp, 385lb-ft
93-95 LT1 F-Body: 275bhp, 325lb-ft
96-97 LT1 F-Body: 285bhp, 325lb-ft
96-97 WS6/SS: 305bhp, 335lb-ft
93-97 Firehawks: 315bhp, 340lb-ft
Factory LTX Camshaft Specifications**:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
hope this helps
Mar 04, 2015 | Cars & Trucks
What is theproblems in using cast iron valves for water pipeline
For drain pipes (waste water) they're fine.
But for potable water (fresh water), the cast iron could rust, allowing the rust to get into the water.
Also, the iron could leech into the water.
Apr 28, 2014 | Plumbing
Need a diagram for all the valves on a 1960 cast iron powerglide transmission
Results for "diagram for power glide transmission 1960": Pronto.com/Powerglide Transmission Powerglide Transmission Find our Lowest Possible Price! Powerglide Transmission for Sale produtools.com Manuals Online Looking For Help & Support? Manuals Viewer toolbar download 100% Free! good luck!
Dec 05, 2013 | Vehicle Parts & Accessories
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
I need the serpentine belt diagram for a ford
Here are two links to take you to the serpentine belt diagrams... choose your engine type.
V6-24 valve engine
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S5021
V6--12 valve engine
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S7021
Oct 27, 2009 | 2001 Ford Taurus
When told your car needs a valve job, what does that mean
A valve job is removing the cylinder head(s) from the engine so the valves, guides and seats can be refurbished to restore compression and oil control. A valve job may be necessary by the time an engine has 80,000 or more miles on it, or to fix a "burned valve," compression or oil burning problem.
Before we describe all the steps that a typical valve job involves, we should warn you that some shops don't necessary do all the steps. In other words, you get what you pay for. A "cheapie" valve job might skip a lot of things that saves you a few dollars in the short run, but may end up costing you a lot more in the long run. So look for a shop or service facility that does quality work.
A valve job typically begins by disassembling, cleaning and inspecting the cylinder head. Cast iron heads are "Magnafluxed" to check for hairline cracks. This involves applying a strong magnetic field to the head and sprinkling iron powder on it. Cracks disrupt the magnetic field and attract the iron powder, making invisible cracks easy to see.
Cracks are bad news because they can leak coolant into the combustion chamber damaging the cylinders and/or causing the engine to lose coolant and overheat. If cracks are found in any critical areas of the head, the head must either be repaired or replaced. Cracks in cast iron heads are most often repaired by "pinning" (installing a series of overlapping threaded pins). Cracks in aluminum heads are very common and can often be repaired by welding.
If a head has been repaired (pinned or welded), most shops will usually pressure test the head afterward to make sure there are no leaks. Some may also apply a sealer compound to the inside of the water jackets as added insurance against future leaks.
Once the head passes this point, it is also checked for flatness. The surface of the head must be flat to seal the head gasket against the block. Excessive warpage, roughness or any damage can cause the head gasket to fail. If the head exceeds the maximum allowable out-of-flatness specs, it must be resurfaced or replaced. Usually there's enough metal in the head to allow for a certain amount of resurfacing. But on many import aluminum cylinder heads, the amount of resurfacing that's possible is minimal.
Overhead cam aluminum cylinder heads are often found to be warped (usually the result of overheating). If the condition cannot be corrected by resurfacing, the head can often be straightened by heating it in a special oven and then bending it until it is straight.
Next come the valves, guides and seats. The guides are checked for wear. They're almost always worn, so they either need to be replaced, relined or knurled (a process whereby grooves are cut into the inside diameter of the guides to decrease the bore size). Few shops knurl guides anymore. Most install new guides, guide liners or bore out the old guides to accept new valves with oversized stems. Aluminum heads have cast iron or bronze guides that can be replaced but most cast iron heads do not.
If the valves are to be reused, they will be inspected, checked for straightness then refaced. Many shops automatically replace all the exhaust valves to reduce the risk of failure (exhaust valves run much hotter than intakes and are much more likely to fail).
The seats in the head are either cut or ground to restore the sealing surface. If a seat is cracked or too badly worn to be refaced, the seat must be replaced. If that isn't possible (as is the case on many late model cast iron heads because the casting is too thin), then the entire head must be replaced. All aluminum heads have hardened steel seats that can be replaced.
The valve springs are all inspected and tested to make sure they are still capable of maintaining proper pressure. The spring retainers, keepers and other hardware is likewise inspected. Any worn or damaged components are replaced. New valve guide seals are always used.
The valves are then installed in the head and shimmed to restore proper valve height. This is necessary because machining the valves and seat alters their dimensions. Valve height is important because it affects valvetrain geometry and guide wear. If it is an overhead cam engine, the cam is also installed and the valve lash adjusted prior to returning the head to the customer
Sep 18, 2009 | 1992 Toyota Tercel
Idle problem
change your PCV valve, if your car dies cause it idles down and shuts off......had the same problem but my battery was fine, PCV valve is less then 3 bucks and autozone or whoever will replace it for you free ^_^
Mar 20, 2009 | 1998 Mitsubishi Montero Sport
Unloader valve leaks on my compressor leaks air constant and I think that it must need replacing, does it? just old or what?
THE VALVE COULD BE BAD BUT IT MORE LIKELY THE CHECK VALVE IN THE TANK ISNT CLOSING. DRAIN PRESSURE AND REMOVE CHECK VALVE FROM THE TANK AND INSPECT.
Mar 08, 2009 | Campbell Hausfeld Single Stage Air...
Plumbing Logo
229 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
