Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer not cold enough ice is melting in bin
I have kenmore coldspot ref. model # 71289100 serial # EL4512383 Mfg. date 11-01 . Freezer on top with ice maker. The freezer is not cold enough to keep the ice from melting in the storage bin. or my food frozen. The vent is not blocked. I turned thermostat to 7 the highest setting did not help. The blower is working but the air coming out is just not cold enough.
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
  • 572 Answers
SOURCE: we have Kenmore Coldspot Model #106
check your compresor if its running. relay can fail in compressor
Posted on Feb 11, 2010
  • 2525 Answers
SOURCE: We have a Kenmore coldspot
you have a blocked drain.when the machine defrosts the ice melts off the coil and the water drains down to the bottom of the machine where the compressor is and the condenser coil.it gets hot down there and the water evaporates.your drain is blocked and the water isn't making it out of the freezer.take out all the food in the freezer,remove anything else in there and remove the back inside wall of the freezer,unplug it or shut down the control,then with a hair dryer melt all the ice,i use a steemer to clean out the drain but you can use a baster or anything that will blow through or force air down the drain to clean it out.when you think it's clear pour hot water down the drain hole to see if the water goes down the hole,if it does then it's clear if it doesn't keep blowing through the line,when you clear it you can buy a heater,all it is is a piece of metal that raps around the heater,you stick it down the hole so when the heater comes on the metal heats up and the water wont freeze in the drain line.you need like a 6 inch long piece of wire from a cable wire or from a wire that you use to hook up a lite,use the ground wire or the copper piece in the cable or lite wire,strip off the casing and stick the wire down the hole and cut it with enough wire to rap around the heater and this should take care of your blocked drain.a steemer works the best,stick it in the hole and blast the steem down through the drain,it clears everything out of it.good luck
Posted on Jan 29, 2011
Sea Breeze
  • 4654 Answers
SOURCE: frigidaire glrs267dzw2 side-by-side mfg 11/2004 -
Looks to me your model had the older style ice maker that uses micro-switches to tell what is next in the six parts of one complete cycle. Some times those switch's stick on or off and tend to break. Here is a link to an exploded view=> 5303918344 Ice Maker Exploded View
Let me know if you have any questions so I may help you better, Thanks, Sea Breeze
You can try to disassemble and repair, just be aware that the lever spring will be the hardest part to understand putting back in if you by chance pull the facing off it can jump out of its location giving you hours of fun trying to return to its proper place. The ice maker replacement part is=> Click on photo or 5303918344sea_breeze_71.jpg
Posted on Feb 10, 2011
SOURCE: I have a Kenmore Coldspot
i have a kenmore top freeze and the freezer isnt working, cant hear the fan running , but the ice machine is working ,what do u suggest/
Posted on Jun 13, 2011
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Refrigerators
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
Kenmore coldspot refrigerator, 2003 model. Serial #ep1732308. Cold water leaks onto the floor from the refrigerator. Collects under the vegetable bin, once or twice a day, but not sure. Do you know what's...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Sep 08, 2010 | Refrigerators
Kenmore Coldspot not keeping cold. Ice in freezer
What are your temp controls set to? If the controls are set to the max setting and it won't reach temp, you could have a broad range of problems ranging from bad door gaskets, to bad temp controls, to a low refrigerant charge, to possible a failing mechanical part such as a fan motor or compressor.
Jan 08, 2010 | Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore coldspot fride problem
The water line could be frozen. Take a hair dryer and heat up the tube where the water enters the ice maker. MAke sure it doesn't get to hot and start melting the plastic,
Feb 01, 2008 | Refrigerators
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
