Question about Plumbing
Low water pressure- have a home water well
We have a water well and for some reason the pressure is low coming out of the showers. If we run two sinks at a time they become slow too. We just had a new well pump installed. I read something about seeing if the filter is clogged. Where is this filter located? Is it in the well itself? We just changed the house filter so i know that is not the problem. Help!
  • argre3 Jan 15, 2009
    in our home my mother-in-laws side of the house water pressure is low in the sinks and the shower, oh yeah also in the washing machine.
  • 700 Answers
Take a regular tire presssure guagge and go to where you bladder tank is and there should be a removable cap that you can remove and then check the pressure that you have in the tank. If you only get water out then the blader is gone. if there is no pressure then you will have to charge it up. recommend aroud 60 psi and the reinstall the cap. also the filter that they are talking about is probably a strainer and it should be in the line before the pump. Good Luck
Posted on Dec 24, 2008
    Problem Solver:
  • 15 Answers
There is usually a metal filter at the wellpoint on the bottom of your drop-tube, but I don't think that is the problem if you are not getting particles in your water. This is easy to check for just by putting water in a glass and looking for little specks.
I would be more inclined to look for holes in the drop-tube where AIR is getting into the system, thus reducing the suction of the pump.
If you are using a "bladder tank" to maintain pressure, it could be that the "off" setting is too low. You want that to be in the 50-60 psi area. "ON" should be about 40 psi.
Anyway, I think an air leak is the more likely problem, but to find out for sure, you almost have to pull the drop-tube, which might be very long. That would best be left to a well service company.
Posted on Oct 10, 2008
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
No shower pressure in rv
Make sure you have enough water in the tank or city water hooked up. A pump will run and suck air if the level is low. it could force water to the sink, etc, but not the shower.
Are your valves for the water pump set correctly? Remote possibility someone installed a shut-off valve between the pump and shower.
Could be the pump is getting weak/leaking internally and can't build enough pressure.
Make sure the shower head is not clogged. Remove it from the hose and try again.
Apr 22, 2014 | RVs
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Shower head
There is a California water saver on it that can be removed, just a little piece of plastic that covers the opening. Why do you have low pressure? Are you on city water? Well? Jet pump? Turn up the pressure cut off. Check it out.
Jun 26, 2010 | Home
Water heater works but low pressure at sink and shower. Is there a filter or screen at the output line that may be clogged?
Take the aerator off the sink spout and see if your pressure is good without it on there. Sometimes they get plugged causing that problem, usually after you have had the water disconnected and turned back on again. If that works, do the same with you shower head. If the tub spouts runs good and not the shower head, then that is also a good indicator of that being the problem.
Sep 17, 2009 | Water Heaters
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Plumbing Logo
483 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
