I have a zyxel p66ohw router connected to my pc via an ethernet card, everything is fine untill my son logs on with his playstation 3, or my wife logs on with her laptop then i cant connect everytime i try iget an error message saying cannot connect
  • 749 Answers
Make sure that your TCP/IP properties are set to "Obtain an IP address automatically". If you still cannot connect after you change that, and after waiting for a couple of minutes, then open a command prompt and type "IPCONFIG". Make a note of the address at "Default Gateway . . . . . . . . . :" That's the address you need to go to to access the modem's settings..You'll need an ID and password. These would be in the modem's manual.
---to find tcp/ip properties---
It depends from PC to PC, but, try this:
Start (Bottom left of your screen)
Settings
Network Connections
Local Area Connection
Properties
Internet Protocol TCP/IP
Properties
That's how it is on my PC.
Posted on Oct 10, 2008
II have been trying to connect wirelessly my new HP lap top to an old series 600 but the computer can't connect even after entering the key. It works ok on cable.can any one help
1. your issue is due to a a wireless laptop is not compatible with the old router or
you may need a firmware upgrade.
2. the cold compute may be able to connect via a cord (Ethernet) but not wirelessly due to an outdated driver for the network card ( the card will need updated drivers also) if it is a wireless b card then the ability to us a WAP key will not be possible
because your card was designed to use WEP key.
3. a new wireless G card installed to the old PC will allow connectivity if the wireless card is backwards compatible.
4. most all PC's can connect via a Ethernet cord they are all designed that way and have not changed for the 20 or 30 years they have been in use.
I hope this helps. Have a great day!
Oct 05, 2010 | Zyxel P660HW-D1 Router
Forgot my securty key for zyxel p66ohw
Log on to the router by typing the IP address into a web browser. This will log you into the router.
Once logged in you can select the "security" section and find your security key.
If you no longer have the password to log in you will need to reset the router. You can reset it by pressing a pin inot the pin hole on the back of the router near the AC adapter plug.
Thanks
Jun 07, 2010 | Zyxel P660HW-D1 Router
I have tried "admin" and "password" to get in to get my WEP key to add my sons netbook to our router, but it is not working. Can I reset the original login and password?
if you feel you are apart distance than other peoples wifi connections and safe,, then you can diable pass word in settings,,and log to your sons notebook..
Sep 28, 2009 | Zyxel Prestige 334 Router
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
My pc wont connect wirelessly to my zyxel p66ohw router
- Try to reset the router for 10 seconds
- Run the setup wizard to the computer
- Make sure that you configure it as the same as before
- Turn off the modem and router for 5 minutes
After the Steps check the Internet connection again.
Mar 10, 2009 | Zyxel P660HW-D1 Router
I need to secure my Zyxel wireless connection
Connected pc via ethernet cable then went to 192.168.1.1.in IE deleted dots in password box and entered 1234. Clicked continue and ignore on next page. Then found menu on left. Followed my sp tech support tecnician and was able to connect
Jan 16, 2009 | Zyxel P660HW-D1 Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
May 20, 2008 | Zyxel Prestige 660R Router (91004397002)
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
