Question about Haier HDN655E Dehumidifier
Defrost Light I have a 2 year old Haier dehumidifier. Recently the defrost light has been coming on & staying on. I took the unit apart & gave it a thorough cleaning, but it did not make a difference. The unit does not work at all when plugged in. The defrost light just keeps blinking.
IrishDruid
  • 2712 Answers
SOURCE: Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
heatman101
  • 43501 Answers
SOURCE: haier hd656e, my dehumidifier runs about 30 sec and turns off,
This sounds like a main circuit board problem and is very common with many dehumidifiers... They can be replaced on some units. You can do a search online for the part easily...to see if it is available.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: My HDN455 45 pint Dehumidifier did not work
heatman101
heatman101
  • 43501 Answers
SOURCE: Dehumidifier icing up - no defrost cycle
The unit may be leaking freon...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 30, 2010
dcramer531
  • 1654 Answers
SOURCE: how to defrost a dehumidifier lost instruction
Simply turn it off and let it set! this will allow the coils to thaw.
Posted on Nov 27, 2010
A bypass to well no longer occurs,; instead the bucket keeps filling up...also can't pull the filter out for cleaning purposes... In addition are we defeat ing the purpose of the dehumidifier by placi
well if the unit has never been taken apart and cleaned well inside, and it's five years in service , Id say thats your problem, anything thats got room air blowing thru it for five years ,It's gonna need to be tottaly cleaned in all areas
Dec 23, 2014 | Danby DDR6009REE 60 Pints Energy Star...
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
Only 3 years old. Fan runs does not collect ANY water. #1 We have it set at Maximum #2 How exactly do we take it apart to clean filter? #3 Clearance space is ok #4 Temperature in basement ok please...
First turn the Master ON/OFF Switch to OFF & Unplug the unit.
Depending on the model, (in both cases, the filter is behind the louvers on the front) by removing the water collection bucket and looking up into the water bucket cavity, just behind the louvers, for what will look like a plastic pull tab handle. If you see this, pull it straight down an out.
If the filter is not there, look on the right hand side of the unit, just behind the louvers. There will be a trap door that will flip open, There you will see the plastic frame of the filter. Pull it straight out to remove it.
The filter can be vacuumed or if it's really dirty, wash it in warm water and dish washing liquid, rinse thoroughly and allow it to completely dry, before reinstalling it. NEVER operate the unit with out the filter installed.
Hope this helped you.
Jul 07, 2011 | Haier HD308 Dehumidifier
Display lights up E 1 nothing else happens. What does the E 1 mean? Unit is 4-5 years old.
On models a lttle later than yours E1, indicates that the air intake filter needs to be removed and cleaned. Probably, the same thing as yours. Before doing so, turn the Master ON/OFF Switch to OFF and unplug the unit. If you wash the filter use warm water and dish washing liquid, Rinse thoroughly and allow to completely before reinstalling. DO NOT operate the unit without the air filter in place.
Hope this helps you to troubleshoot and solve the problem.
Jun 26, 2011 | Haier 45-Pint Dehumidifier
Why is the defrosting light coming on periodicaly.
Defrosting is a normal function of a dehumidifier. When the evaporator gets too cold and starts to ice, the dehumidifier goes into defrost mode to clear / stop the ice formation. How often is the defrost light coming on and does the dehumidifier seem to be dehumidifying as expected ?
Charlie
Feb 01, 2011 | Danby DDR4010E Dehumidifier
I am only getting about 1 qt of water every 24 hrs. and it is in a very humid area. the compressor is running along with the fan. the coil is iceing over. the unit goes into defrost mode yet water is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jan 22, 2011 | Haier HDN455 Dehumidifier
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Haier hd656e, my dehumidifier runs about 30 sec and turns off,
heatman101
May 16, 2010 | Haier HD656E Dehumidifier
My Haier HD601 dehumidifier keeps popping breaker
If you are blowing the breaker then you are pulling way to much current on the startup or you have a short in the unit...
either way you probably will be much better off by replacing the unit with a new one... they do not cost enough that it is worth sinking hundreds of dollars into fixing an old one...
heatman101
May 03, 2010 | Haier HD601 Dehumidifier
Haier HDN655E Dehumidifier Logo
101 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
