Question about Nintendo DS Lite Console
Nds lite wont turn on
The on/off switch does not turn the ds on. console charges ok but will not turn on
  • Anonymous Mar 26, 2009
    same here! ok like i plug it in and than its orange for a bit and than it goes black! and its weird.
    Problem Solver:
  • 13 Answers
If green light flashes on then of when powering up (which i coz charger wud do same if so) then its ur f1 or f2 fuses or both that have blown and need bridging over with solder (replacing them very difficult), both are labelled on motherboard so not too hard to find (f1 is below charging point and f2 is below that near bottom right hand slot type 1 port). if green light does'nt flash on at all then check the l2 inductor (small black chip) is stiil in place has this is prone to falling off (its situated directly below the power switch labelled L2, if loose resolder it, if missing hunt around in ur nds 4 it as shud b sumwhere. if u cant find it buy 1 from ebay (type in L2 inductor there is 1 seller and price is £2.85 inc p+p) oh and purchase a tri-wing screwdriver also if u havnt got 1. if u havnt been inside a nds b4 then youtube it and be carefull not to snap power lever off. good luck and let me no if it worked
Posted on Mar 26, 2009
  • 23 Answers
There maybe something wrong with the jack inside your Nintendo DS, you can easily get them repaired at a few shops, just tell them that the On/Off switch doesn't turn the DS on and they'll fix it for you, shouldn't cost an awful lot as they're just replacing something inside.
Posted on Oct 10, 2008
Hi Their is an error that comes on my ds lite it come when i play on the r4 . it says...
What i will do is try and run nds mood, and if not.
OR
Remove the battery cover using a screw driver and hit the reset button.
Mar 03, 2011 | Nintendo DS Lite Console
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
My ds wont charge or turn on
Have you tried a different battery before anything else? Most of the problems I get with these are the battery
May 28, 2009 | Nintendo DS Lite Console
Hello my Ds wont charge
Batteries lose their capability of holding a charge over a certain amount of time. Buy a new battery at
http://www.calcellular.com/ntd-ba-usg.html for ds lite
or
http://www.calcellular.com/ntd-ba-nds.html for ds.
Jan 11, 2009 | Nintendo DS Lite Console
Ds lite not working
i had same problem ( bought a faulty nds off ebay and would charge but nothing when powering up, not even a blink of green light) problem is a component called a L2 its an inductor 33uH in case SMD 1007. its situated dirrectly under the power switch but they are prone to fall off when nds is dropped ect. you need to resolder it on (very tricky). give your nds a shake to see if you can hear it rattelling about. be carefull when opening your nds not to lose the part (its very small, about 4mm long 2mm wide) GOOD LUCK
Jan 05, 2009 | Nintendo DS Lite Console
My DS power
How long have you had that battery in your DS? The more you use (play and charge) the battery, the battery's capacity is decreased. Try getting a new battery at,
usg.html">http://www.calcellular.com/ntd-ba-usg.html (for DS lite)
or
nds.html">http://www.calcellular.com/ntd-ba-nds.html (for DS).
Your welcome
Dec 29, 2008 | Nintendo DS Lite Console
Ds lite
GO ONTO R4 WEB SITE DOWNLOAD LATEST FIRMWARE PUT ON TO SD CARD,THERE IS SYSTEM,MOONSHL,DS MENU DAT,DS MSHL NDS THEN IT SHOULD BE OK.
Nov 14, 2008 | Nintendo DS Lite Console
Nds lite doesnt power off
Dear Cornjo,
Your situation has baffled me completly. Here are some solutions that might help you:
  • How old is your DS/DS Lite? If it is less than 1 year old or if you have a gurantee for more than 1 year, you can take it back to the shop.
  • Try taking out the battery and not putting it back for at least 24 hours
  • Charge your DS COMPLETLY and do not use it for a while
From Andrei S.
Aug 17, 2008 | Nintendo DS Console
R4DS
what is R4DS?
Dec 26, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
203 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
