Question about Kenmore 72802 Gas Dryer
Kenmore gas dryer after 5 to 10 min. later no more heat
Kenmore gas dryer model #11072832100 serial #ML1502544.
is around 7 years old, everthing working fine but after 5 to 10 minutes later there is no heat and drum keep working and air duct area is very clean, please someone can tell me what's the problem?
thank you....
  • 2 more comments
  • gearz58 Oct 13, 2008
    my Kenmore gas dryer seems to start fine but heat shuts off after 5min.
  • doc_218 Oct 21, 2008
    I have the same problem. I have found that the ignitor continues to work, however the gas stops igniting a couple of minutes into the cycle.
  • Anonymous Feb 04, 2009
    the dryer is turned on but the ignitor doesn't glow, I feel it's the ignitor is there somthig else I should look at?
  • Anonymous Mar 30, 2014
    It's Type DWSR NAT 1206006FM22
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
Had the same problem. I replaced the valve solenoids - problem solved. The valve on my model was located front bottom left. Take off top cover, tilt front panel forward to remove.
Posted on Oct 26, 2008
My Kenmore 80 series (model 11072802100) has the same problem that it fires up first and then stop producing heat after a few minutes. It's also 7 years old. After a while, if I restart it, it will run and do the same thing. I found a thread of discussion on another forum that says that this can be the gas valve coil (solenoids) problem as these coils turn on and off the gas flow to the chamber. I'm going to check out the coils, but don't know where they are located (can't find the manual). If anyone has any idea, please share. Or I'll just tear off the top and back to see where they are.
Any gurus here to help? Thanks.
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
No heat
the most common problem is the thermostat if its bad the dryer thinks its overheated you can us ally jump them however its not recommended because of safety issues
Apr 30, 2009 | Dryers
Whirlpool gas dryer two years old does not heat.
If you remove the rear cover on your dryer after unplugging it, look for a small white piece of plastic about 1.5 inches long with two wires attached to it. This is the fuse. Can I help with anything else?
Eric Campion
Feb 16, 2009 | Kenmore 73952 Gas Dryer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore 72802 Gas Dryer Logo
375 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
