Question about i-mate PDAL Pocket PC
Problem with i-mate
Cannot copy files to imate from computer.cant even synchronise
    Problem Solver:
  • 12 Answers
Cheack activesync settings on your pdal and reinstall activesync on your pc
Posted on Jun 06, 2010
  • 3 Answers
Try ( wm5storage) software
Posted on Oct 21, 2008
I have downloaded to my computer the profile controller file. how do i install profile controller on to my imate 9502
Well, if it is a .zip or .rar file, unpack it on your computer, until you get a .cab file. Copy this .cab file to anyhwere you want on your phone, and tap over it. If you are prompted to choose the installation place, I think this type of application would work better in the internal memory.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Dec 31, 2010 | i-mate Ultimate 9502 Cell Phone
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
PDA2k Pocket PC: how do i install antivirous in my imate pda2k?...
download this file.copy to your device and run!
http://bit.ly/aVZeLE
May 06, 2010 | i-mate PDA2k Pocket PC
Mate Jama shows only blue screen.
i tried to update my Imate JAMA's rom to WM6, while i was updating my phone it went power off as it was out of charge. now the problem is this i cant switch on my phone, it dont even shows the blue screen, even my battery i fully charged. Is this because my Imate's ROM? which i was trying to upgrade? I need a solution plzz
Jan 07, 2010 | i-mate Jama 101 Smartphone
Free Software to Download
go here
http://gallery.mobile9.com/c/imate-jam-java-software_159/1/
Sep 20, 2009 | i-mate JAM Pocket PC
How to restore i-mate to the factory settings
how to synchronise imat jam with computer?
Nov 27, 2008 | i-mate JAM Pocket PC
Imate is dead after upgrade
go to http://www.imate.com register there and give your device info while registering and download WWE rom from there and istall it using active sync
krishna
Jul 21, 2008 | i-mate JAM Pocket PC
Drivers for imate jam
http://www.ziddu.com/download/3568715/Imatepcsuitactivesync4.zip.html
here is the software for your imate pocket pc.
if you want more softwares or any other things please send me your e-mail. I'll send you More Links.
my e-mail : dhanushka_priyankara@yahoo.com
May 25, 2008 | i-mate JAM Pocket PC
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
I-mate Jam Boot problems
look sir,
the operating system should be installed from your PC not from the i-mate
so  you will have to do the following:
A- install microsoft activsync to connect the i-mate to the PC
B- download the windows 6 file
C- connect the i-mate to the PC then open the windows 6 file by double click it , it will guide you to instll the operating system on your device
note:
windows 6 mobile will not properlly work on i-mate jam you will find a problem when you use it,
so my advice is to install the 2003 CE and install all it's updates this will be batter than that
Dec 04, 2007 | i-mate JAM Pocket PC
i-mate PDAL Pocket PC Logo
52 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
