DVD/RW Drive I installed a SATA DVD RW drive, I also have a SATA HDD. Also have a IDE CD-RW drive installed along with two IDE HDD. Everything works fine, except when I try to right click on a file and click on Send To my pc reboots. Windows XP Home SP2
  • 1,605 Answers
What else you have on the pc???
sound like you have too many attachment. try to go into the BIOS and see if there any setting you foregot to set.
Posted on Oct 10, 2008
Replacing DVD/CD drive
Look inside of your tower, you will have a few different cords connecting to your DVD/CD drive.
It should either have a 4 pin Molex connector and an IDE or a Sata connector and power.
The IDE cable looks like this:$OD%2DLarge$
The Molex connector looks like this:
IDE is an older tech that uses a 4 pin molex to connect it.
Now, if you have something that looks like this:
It uses Sata, and the power cable looks like it as well, it's just longer.
To make sure the DVD drive you're working will work with the current DVD/CD's you have, just look on the front of the CD you are going to use, in truth it usually should work with anything. It's even RW so you can re-write data to RW CD/DVD types.
Pretty much, just make sure that it uses the same power type and data connector as your current one. Power type being the 4pin molex or the Sata power plug. Data type being the IDE cable or the Sata cable.
If it matches, it will work :) I hope this helps.
Feb 26, 2013 | Dell Inspiron 530 Desktop Computer
I want to install a CD/DVD RW drive. This is in addition to the installed CD/DVD already in place. The new drive has a SATA connection on the back, and the only available connector is an IDE connector....
There are IDE to SATA adapters and cables, such as this one linked below. IDE to SATA Adapter
You would simply plug this adapter into the available IDE connection on your motherboard, then use the SATA data and power cable to connect from the adapter to the CD/DVD drive. You can look around online for similar products, but they should get the job done!
Mar 05, 2011 | HP (REFURB) HP XW4200 XPP P4 3.4GHZ 80GB...
How to install seagate hdd into optiplex gx520...please help me...
I see you are trying to use a IDE HDD in a system that is meant to use a SATA HDD. If you have a desktop version of the Gx530 (not the small form factor) then you can still use the IDE. You will just have to put it on the ribbon wire as the CD/DVD drive. You will then need to have a power wire splitter to share the power for the DVD as the SATA power wire will not work on the IDE drive.
This only works on the desktop (larger) models, if you have the SFF or the USFF then it will not work as they dont have the IDE ribbon.
Hope this helps.
Feb 18, 2011 | Seagate (ST380011A) 80 GB IDE Hard Drive
Not apearing on my computer
1.Install the driver disk that came with the drive.You can even download the driver from the internet from here- .
2.If the drive does not work still then check out the connections made in the system i.e power cable,IDE/SATA connector also check that the data cable {IDE/SATA} is not faulty.Heck the jumper settings See the drives user maunal to check for jumper settings or try to find the printed sticker/label on the drive
3.If drive does not works your drive is faulty hope this solves your problem..please don't forget to rate me ....
Dec 04, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
What type of dvd drive can I install on emachine w3118 IDE or SATA?
This computer has a IDE and SATA port inside it so you can either install a IDE or SATA drive on it, but what it came per built is a IDE drive.
May 19, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Wont boot
    go to BIOS and enable the secondary drive auto detect.
    if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
    Apr 02, 2009 | Intel Motherboard
    945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
    Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
    Feb 26, 2009 | Computers & Internet
    Sony Dual DVD +/- RW
    set the hard drive to master and the dvd to slave
    Jan 24, 2008 | Computers & Internet
    DRW-1814BLT compatibility with IDE hard drive
    put hard drive as Master. dvd rw as slave!
    if DVD comes with sata then just put hard drive as master.
    configure it on the bios setting!
    if it still don't detect it
    try replacing IDE cable and sata cable!
    Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
    Computers & Internet Logo
    David Payne
    David Payne
