Need to make a secure system - Computers & Internet
    Genius:
  • 1,605 Answers
Of what??
wired or wirless????
Posted on Oct 10, 2008
Thinking 99 Chevy Astro van security light on solid band starts with cuts down is there anyway to bypass security without spending a lot of money
If the light is on there are code stored ! Not in the PCM/ECM engine computer . In the BCM , do you know what that is ? body control module ! Need a factory scan tool or equivalent to check !
DTC B0688 Security System Indicator Circuit High
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3031 Security System Controller in Learn Mode
DTC B3033 Security System Indicates Tamper
DTC C0559 EEPROM Checksum Error
Why does everyone want to chop up things , by pass etc... The right fix could be cheaper then ruining your vehicle . Chopping up wiring harnesses . Their are by pass module , don't know how much they are . It may or may not fix the problem . Pulling the code and doing the diagnostics is still the best solution .
Jan 07, 2017 | 1999 Chevrolet Astro
I need to know where exactly is the fuse that controls the security system in a hhr chevy 2006 is located in the panel. I do not have a owners manual.
Security system ? your vehicle has two ! Content theft and anti-theft that prevents drive away theft ! Is the Security Indicator lit on the instrument cluster ? If the light is on it's not a fuse issue . You need to take or have towed to dealer . Nothing your going to be able to do .
The security indicator on the instrument cluster is controlled by both the VTD System and the CTD System. The security indicator is controlled by the body control module (BCM) via a discrete output.
Dec 17, 2016 | Cars & Trucks
Need radio code for 2006 suzuki FORENZA
A local dealer can help. They will have a code based on your VIN. Also, you can try this: The audio security system is activated whenever the audio system circuit is disconnected from the battery. A four-digit security code must be entered in order for the audio system to resume functioning. The security code is stamped on a card located in the vehicle (usually in the glove box). The following security code entering procedure must be used to deactivate the audio security system:
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
If, after repeated entry of the wrong code, unit will enter "lockup" & will need to be repaired
Oct 07, 2015 | Suzuki Cars & Trucks
Hi,please i need your help.When i try to start my car,on the screen show me that engine disabled,please i need your help.
Your security system is restricting access to the starting capabilities of the vehicle.
Here is some helpful info about those security systems.
Security and Alarm System Operation Diagnosis on RangeRover 4 0 4 6 P38A
Sep 15, 2015 | 1995 Land Rover Range Rover
How to Effectively Secure Your Home with A DIY Home Alarm System?
The best type of security system to get is a wireless alarm. This is easy to install for anyone, even with no prior experience and it has no wires to contend with. This means that it can be added any place in your home to provide you with the best security you can have. Plus, you will easily be able to secure any area of your house that is vulnerable.
Best Home Alarm Systems
Oct 15, 2014 | Home Security
Is it worth it to get a home alarm system or can I just install one of those DIY ones?
I think its worth the money. DIY systems are not so reliable and you always have false alarms-stressful. If you don't want to spend money, buy a fake alarm system box online. Then it just looks like you have an alarm system which should scare off any burglars.
Jan 16, 2013 | Home Security
HOW TO DISARM SECURITY SYSTEM
The system is automatic and disarms as soon as the key is used or the remote. If it is locking you hurt then it has a fault in the system and you need to have the security system scanned by the GM dealer to see what is locking you out.
Jul 04, 2012 | Cars & Trucks
I have a 2002 BMW K1200LT motorcycle. i am trying to locate the program plug under the seat to reset the alarm system.
HI,
Do you have a factory system or aftermarket? What has gone wrong so that you need to reset it?
motorcycle security chains
http://security-chains.com
Jan 02, 2011 | K1200lt Motorcycle Security Alarm System...
1987 cadillac brougham security system
Find the fuse for the security system and remove it. This should diable the security system, but on most cars that I have seen this, the security system won't stop the car from starting and you may have another problem. I would try removing the security's fuse and see if it starts though. Most of the older security systems like yours are very limited and are basically junk. If you get around it by pulling the fuse, I would leave it that way and if you still feel you need the security system, I would have one installed at a car stereo center, which will be much better than the one that came with the car.
Dan
Dec 15, 2008 | 1995 Cadillac DeVille
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
