No communicatiom between comp./printer. there was , upon installation. I am not totally comp. literate , yet.
Please let computer communicate with my printer (cannon BJC-4300)
Posted on Oct 10, 2008
  • FIKO5 Oct 10, 2008
    HOPE YOU RESOLVE THIS PROBLEM SOON THANK YOU
I'm trying to scan to my computer & I'm getting a msg "No connection. Turn on or connect comp. or install HP software." I am connected to the printer. Can you help?
First step for ANY HP product is to first power it down completely, which means disconnect all of the cables from it, usb, printer, power supply, etc., and let it sit for a minute or two. This will usually allow the printer to reset its processor upon powering up.
If your PC does not recognize it at that time then I would suggest re-loading the drivers that work with your operating system.
After that all I can suggest is that there is a bad usb port, or whichever connection is being used...
Nov 20, 2010 | HP PSC 950 All-In-One InkJet Printer
Broken hp s5111uk
the cd/dvd might have gone bad
try uninstalling and reinstalling the dvd drive frm device manager..... go to device manager and then right click on the dvd drive and click on uninstall and tehn restart the comp
Feb 08, 2010 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
What are the fluid capacities for the 06 qd-2
5.7 liter V8 Engine code 2: Fluid capasity: Engine oil with filter 6.6 liter 5W-20,  Cooling system: Total fill 13.7 liter Automatic transmission total fill 13.3 liter Front differential 1.7 liter Rear differential 2.23 liter Transfercase 1.8 liter
4.7 liter Engine code N Fluid capasity: Engine oil with filter 5.7 liter 5W-30 Cooling system: Total fill 13.7 liter Automatic transmission total fill 13.3 liter Front differential 1.7 liter Rear differential 2.2 liter Transfer case 1.7 liter
3.7 liter Engine code K Fluid Capasity: Engine oil with filter 4.7 liter 5W-30 Cooling system: Total fill 10.0 liter Automatic transmission total fill 13.3 liter (W5A580 7.7 liter) Front differential 1.7 liter Rear differential 2.2 liter Transfer case 1.7 liter.
Hope this helps, and good luck.
Jul 03, 2009 | 2006 Jeep Commander
Freezer not working at all, totally WARM. The high temp red light has been on all week.
Compressor not running? have we got power yes, red light on so we must now decide if the stat is us or the comp is a problem. It must have been a hard week for you, get a freezer geezer to give it a once over.
What price new? to replace against a replacement comp if needed. could be an overload reley if there is one but its rare, good luck.
Jun 24, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Mp driver not working
May be the autorun isnt working. Go to Mycomputer and see if you can view the contents of the Cd there. ..connect ur Printer to the system After ...Right click on my comp>properties>harware>device manager>point to the printer >update driver..follow on screen steps.
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cant connect printer to my pc
Uninstall printer software, uncable printer from comp. Go to website for the brand of printer>drivers/downloads>download latest drivers and install>power off comp.> recable printer to comp>turn printer power on>power on comp. Follow wizard intructions.
anonymoose
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Cannot install All-In-One
this uses a usb port..depending on your comp.if you do not have an extra port to use, you will have no problem in buying a hub,which will have extra usb ports. also you will have to unplug-set for 5min or so.with comp off replug printer,then turn on comp.
Dec 19, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Dec 04, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Missing cd to install
the settings should still be installed on your comp acces controll panel and select printer and faxes this should give you a list of printers yours should be in this list if not have you still got disk if you havent the you could access controll paned and select hardware devices and make sure printer is plugged in then let your comp search for new devices when its finished select the printer from the list if you dont have disk it will ask if you have it select no then the comp will serarch for the setting for you but it should still be installed on your comp anyway. have you tried just plugging it in and trying it to see if it works cus your comp might just set itself up any way i hope this is some help to you
Nov 19, 2007 | Dell 1700n Laser Printer
jasbo
jasbo
