Question about Toshiba Computers & Internet
HDD PASSWORD Everytime I open my computer it always appear that an HDD password is needed
  • ver_jhen Oct 10, 2008
    The problem is that I cant boot in without passing through it. Thus, I cant use said computer
  • 171 Answers
This is an optiom in the setup. If you knw the password and wish toi disable it, here are the two methods for access the BIOD Setup Screen
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
Posted on Oct 10, 2008
    Problem Solver:
  • 15 Answers
I am confused as to whether you are getting a BIOS password message when you first turn on the unit, or whether you are getting a HDD password when the operating system starts, so I will suggest methods to get around both.
BIOS Password:
The easist solution is to look for a "password removal tool" which plugs into the parallel port on the computer. You may be able to find one on one of the internet auction sites. Generally, you plug the device into the port, then turn on the computer, turning it back off after a few moments, but here is a link that demonstates some alternative methods, including using "keydisk.exe", a password removal program which fits on a floppy disk.
http://www.laptop-repair.info/toshiba_bios_password.html
One source for the keydisk program is:
http://www.s2services.com/bioscmospasswordfreeware.htm
Look for "Name - KeyDisk for Toshiba" about halfway down the page.
I can't garuntee this will work because I don't have a Toshiba to test it on.
  • Michael VanWye
    Michael VanWye Oct 10, 2008
    If your operating system goes to the start screen, but then asks for a password, you may need to obtain a "password reset disk".
    There are many available on auction sites for just a few dollars, but I would try entering the computer model number as a password, as I have found that to be a fairly common trick people use so they don't have to remember the p-word since it is usually on the manufacturers' sticker on the back or bottom of the computer.
  • 20 Answers
You must have it or you couldn't access the drive. to remove the hdd or power up password you need to enter the bios setup and remove them there or disable them it depends on how the bios is wriiten.
  • len52155
    len52155 Oct 10, 2008
    there's only one problem with these solutions. IF and i say if the toshibas are like ibm machines, if its a supervisor password, it may well be stored in a chip on the mother board and they can be bypassed but it's not all that easy. If it's a hdd password, you replace the drive as IBM openly states they cannot bypass a hdd password.. good luck
How to disable Hard drive password
Did you clear your BIOS to rid yourself of the bios password first? Just making sure you are really looking for the hdd password (which you set while setting the BIOS password I assume) There are some tools out there to help you remove/rest the hdd password but lets be sure that's what you need to do first. Be warned, the tools don't always work and unless you remember the password you might be looking at complete data loss and a new hard drive.
Aug 11, 2014 | Dell OptiPlex 390 DT Desktop Computer...
Sata port 0 wdc wd3200bpvt-22jj5lock
A security lock has been set. Two choices here;- Get the correct code before you are locked out completely or purchase a new hdd as even if you could afford to retrieve the hdd, all data will be lost.
Feb 24, 2013 | Acer Aspire E1-531-4444 15.6" Notebook...
Hi, I have a Toshiba Satellite L350D laptop which when booted up asks for a HDD password (which I do not remember setting at any point). As I understand it, the password is stored on the eeprom on the...
HDD passwords are designed to be 100% secure and there is nothing available to reset or remove the HDD password whether the password failure is caused by human error or HDD defect.
Users must ensure they have regular backups.Unfortunately,a new HDD will be required and is not covered by the standard warranty.
Mar 14, 2011 | Toshiba Computers & Internet
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Everytime I open my laptop. it always appear.. error 0271 check date and time settings.. then he need a password to continue?? can you suggest what other options I can do to continously open my laptop...
It indicate that battery cell which called CMOS has been finished his lift. replace the same with new one set date and time and you will be done INSHALLAH.
Sep 24, 2010 | Computers & Internet
Hdd password pops up and hasn't been setup to ask for it. After trying several words it pops up Hdd error {06801]
Thank you for contacting Fixya. This is Anil.
I understand that whenever you turn ON the computer it pops for HDD password.
It appears that someone has set an HDD password on your computer. Inorder to reset it please follow the steps mentioned below:
If you have forgot BIOS/HDD password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire 5100 Notebook
Bypass HDD password
From what I understand, the hard drive can be set with a password so the drive can't be used in any other computer or even opened if stolen. It is different from windows or bios passwords, and no password unlocker can open it.
You need to call the manufactor of the pc, and have all the information about the computer handy so it can be proven you are the legal owner. They are the only ones that I know of that might be able to reset or disable the HD password.
Jul 12, 2008 | Acer Aspire 3680 Laptop
Hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Nov 05, 2007 | HP OmniBook XE3 Notebook
Computers & Internet Logo
274 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
