Question about LG WM-1832C Front Load Washer
LG front load washing machine will not spin
I have an LG WM0532HW front load washing machine that stopped before finishing a load of laundry yesterday. It displayed the LE on the panel. It will fill and drain water but will not spin. It tries but just barely moves than stops. It is About 5 years old. I have tried unplugging and replugging it in and have cleaned the lint filter but it still wont work. Any help would be greatly appreciated. Thanks, Terry Edwards
  • 4 Answers
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Posted on Oct 13, 2008
MY LG MODEL F1403FDS5 IS SWITCHING OFF AFTER 6MINUTES WHEN ON 30MINUTE CYCLE BUT IF YOU SELECT RINSE AND SPIN IT FINISHES THE CYCLE.
check the ibnlet screens for the water valve,they may be plugged, also make sure the drain hose is above the washer so it dont siphon out as it fills
May 06, 2014 | LG WM2077CW Laundry XL Front Load...
Wm0532hw machine shakes in spin cycle and level is good
Check the machines damper or shock absorbers for condition.
Replace all if one is faulty.
Mar 09, 2014 | LG WM0642H Front Load
Wm0532hw
Make sure that the small plastic feet on the bottom of the machine are all adjusted correctly so that there is no movement on the machine when rocked from side to side when empty.
Adjust by screwing in or out to get the exact level required.
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Front loading LG washer WM0532HW squeeking noise as drum cannot seem to spin with clothes full of water
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Aug 15, 2010 | LG Washing Machines
Error message
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 11, 2010 | LG WM2016C
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Washer spin and not enough water
Spinning both ways is pretty normal. You did not say if your clothes were clean in the end. You may not see much water when it washes, when it rinses you may see about 1/3 thru the glass. Careful with the door aft wash, wait for 2 minutes before opening.
Feb 28, 2009 | Washing Machines
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
860 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
