Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Bissell 8920 won't release fluids at the rollers
I have a bissell 8920 proheat 2x ( the drop down list would only let me put 8910) steam cleaner. We have had it fo about 9 mos. and suddenly the roller sprayers are not working. There is plenty of fluids comming from the hand tool but nothing from the lower side. I have cleaned the spray heads but still nothing. can you help???
  • fidofido Nov 06, 2008
    How do you clean the heater -I have an 8920
  • Anonymous Nov 26, 2008
    brushes are not turning. motor does not work but works directly from wall.
I have an 8920 ProHeat 2x as well with the same issue - no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
Posted on Dec 28, 2008
I had the same problem. Mine would work at upholstery cleaner end but wouldn't spray at the rollers. I took lower cover off (under handle) and my switch that controls the high traffic areas was stuck. There are 2 plungers at the bottom of that switch and only the one was working. I moved switch a few times and the one plunger was stuck. I free'd it up by pressing on it a few times under the switch with my fingers and batta bing the POS worked. My unit is only 4 months old and was used twice before acting up..... Bissell can maybe design these with a little more thought behind it :~(
Posted on Jul 22, 2009
The little red spray jets under the the recovery tank become clogged from hard water deposits. Get a paper clip or longer penny nail and run it through, wash them thoroughly and blow through them to make sure they are unclogged. Worse case scenario like mine was pump failure after only three uses. It also takes out the pump solenoid. No spray from jets or hand unit. Not catastrophic, pump and solenoid were $40.00 all told with shipping from totalvac.com. If you're handy, you can fix it, or take parts(they are genuine Bissell parts) and have a vac guy do it for around 30-35 bucks labor. He shouldn't have a problem with the parts, as they are genuine Bissell parts he would get and mark up 30-50% on you. I fixed mine in one hour fifteen minutes.
Pump part no.: 203-6717- $19.95 Solenoid part no.: 203-6761- $11.95
Model 8920 Pro heat is not the best Bissell out there. Problematic. I've owned better Bissells.
Posted on Apr 14, 2010
Clean your heater out that is in the handle hard water builds up in it and then causes it to become clogged
Posted on Oct 10, 2008
These machines are a joke. something breaks or blows every time i used and then i cant even finish my carpets and ive only used this bissell 3 times!! Bissell needs some major improving or they cant possibly be around much longer.
Posted on Sep 27, 2011
Www bissell com
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
May 05, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat 2x 8920 brushes aren't working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gjkklgj
Dec 27, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
How do I replace the detent pedal on a Bissell Pro Heat 2x model 8920 carpet cleaner?
heatman101
daswae
Nov 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8920 Pro Heat 2X: clogged accessory hose water line....
heatman101
iutio
Oct 21, 2009 | Bissell 8910 ProHeat Clear View Upright...
I have a photo of my 8920 if you want it, along with some drawings I made.
email me at petedcurtis@gmail.com
Apr 04, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
4,263 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
