Question about Home
We don't know how to fix an integrated towel rail to the basin
We have purchased a corner basin with integrated towel rail but there are no instructions to fit the rail onto the basin. various fittings & screws but no instructions.
    Novelist:
  • 171 Answers
Hi stickybrfc,
I'm Harvey the Master Plumber.
Your statement is: You have purchased a corner basin with integrated towel rail but there are no instructions to fit the rail onto the basin. various fittings & screws but no instructions.
I'm going to assime this is a wall hung sink.
The amount of parts will depend on whether it has a round front, straight front or square front. Installation is basically the same. The rod holders have a U shaped connection for the bottom of the apron (the screw goes in the back). Install the first one then a rod then the next one till you're done. You may need a helper to hold things in place till it's secure. Snug up the screws but DON"T OVERTIGHTEN. I find it helpfull to put a little piece of hard wood or rubber between the back of the apron and the screw.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 13, 2008
Hf7 130m. Machine will not go into spin cycle.......will not empty water
water pump is faulty It wount spin when it is full of wate. Put waste pipe down low into a basin to drain it out ...then set spin
Dec 31, 2017 | Washing Machines
How to remove heater core
Really i don't know the exact solution so if i came to know as soon as possible i will be share with you....
Gazebo, Patio Heaters, Heated Towel Rails
Apr 10, 2012 | 2000 Ford Expedition
My asko 1585 overflow switch is activated. I fixed the drain problem now how do I stop the pump from running and the lights from flashing?
Hi drlebo, You can go about that one of two way's. 1) wait a day or two until the water in the overflow basin evaporates enough to satisfy the "overfill float switch" or...2) remove the toe panel and soak up the water in the basin with a sponge or towel, shop vacuum etc. Insuring the power is off first of course. Once that has been accomplished it is simply a matter of pushing any of the keypad functions for 3-5 seconds and the unit should "reset". Hope that help's. Thanks for visiting "fixya" for your repair inquiries. Let me know if I can assist you further and please take a moment to rate the info I provided here for you. Thanks again & good luck. Macmarkus :)
Mar 17, 2010 | Dishwashers
I don't know how to run or find the deep cleaning utility canon 760
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Mar 06, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Output stage scheme for pioneer vsx-d1 channel floating negative.
It should be a push pull. The fact that you have negative voltage almost certainly means push pull. One side will be constructed using NPN transistors ran off the positive DC rail and the other side will be constructed using PNP transistors ran off the negative rail. I don't know the age of your amp but I know pioneer now uses integrated amp modules instead of discrete transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82968/SANYO/STK412-020.html
example of integrated amp module (sorry for the chinese)
Feb 11, 2010 | Audio Players & Recorders
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Rainbow model e2 will not turn on!
Is the basin in place? There is a safety feature that will not allow the rainbow to turn on unless ontop of the basin. Also there should be a tap ontop of the basin that lets the rainbow know it is in place, make sure it is not broken off. If so, you will need to get a new basin. If purchased through a independent dealer, it may be under warranty. Less than 4 years old, everything is covered in the warranty.
Jun 20, 2009 | Rainbow Vacuums
LEAKING WASHER
your pump is leaking ,,, take the 2 screws out thats on each end of the console in front and pull forward and up, take the 2 hold down clips off and tilt cabinet forward and remove / pump is at bottom with 2 hoses connected to it / if you need help getting a pump let me know and send me the complete model number from under the lid and i will see if i cant help you out / larry
Dec 12, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
CANON IP 6700D ERROR6A00
  1. Problem similar on canon ip4300 was solved by removing semi dry ink from black sliding rail. White plastic slide was stuck to the right side (spring was still stretched when printing head I moved to the left). Slide the white plastic slide to the left and clean the rail. This slide must be free to move left and right.
May 27, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Home Logo
187 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
