Question about Watches
Myota Watch Batteries
I have a 25 year old Myota 4800-01A analog/digital watch. Recently, I had the battery changed. I don't think they used the correct battery...it stopped working w/in 2 weeks. What is the correct batery? Or, how can I determine the correct battery?
Try a Maxell 391 silver oxide
Posted on Jun 27, 2010
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
I recently bought a Mossimo watch with the analog and digital faces and the analog runs like ****. It keeps stopping and losing minutes. Like won't go accurate for more than an hour. Worse if it's being...
Quite often the battery can be the cause. But note that on some ana/digi watches there will be two batteries. The battery for the analog is usually buried quite deep in the watch and may be best for an expert to replace this. That expert will be able to test the battery first. If the battery is still good then I would suspect that the movement is faulty and may need replacing (although sometimes a bit of de-greaser expertly administered can solve the issue). Good luck.
Sep 20, 2010 | Watches
I have a jr 8122 and I had the watch battery changed and the people told me that they could fix the digital part but the actual hands were not going around and said that I needed to send it in. Can you let...
this happens a lot the watch you have has to separate batteries both batteries were probably old. they tried replacing both but the movement on the analog part is probably corroded or rusty.
Aug 04, 2010 | Fossil JR8122 Wrist Watch
Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
Oct 21, 2008 | Watches
Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Sep 01, 2008 | Watches
Watches Logo
117 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
