Question about Hanns.G Corporation HU-196DP LCD Monitor
Hanns G 19" LCD monitor Screen Problem
My monitor was working up till today, when it was turned on, i could hear a faint squealing noise coming from the monitor and about 1/3 of the screen from the right was grey and kept changing different colours every time i turned it on and off. the other side worked a treat but the right hand side was bad.
I opened up the monitor and plugged it in again, did the same thing and i traced the squealing noise to the power supply unit but cannot accurately pin point the source but its centered on the power supply board.
Could this be causing my screen to go funny?
And i aint sure if its any of the capacitors of the transformer making the noise either.
Got 2 pictures here, one of the screen and one of the Power PCB & video board.
  • 1 more comment
  • Jonathon summesfield Oct 10, 2008
    This is what the monitor looks like when powered up.
    Update-
    Upon testing the power supply, the squeal becomes alot louder when there is a load on I.E the video sync board but when i remove that, its only a faint one. When the Backlights are plugged in only , the sound is still faint and doesnt become louder.
  • lollybeauty Dec 07, 2008
    the color is green mixer
    Champion:
  • 293 Answers
D3mon,
Looking at the photo that you took... You've defintely got a damaged panel. My advised get a new one...saved you the headached and $$$....
Posted on Oct 11, 2008
My Hanns Monitor keeps going to a green screen and telling me that I have no signal. I have unplugged everything and plugged it back in and it keeps doing the same thing.
change your montior and plug another monitor to check if it is doing the same problem, if it is not working then check your cpu, if is is working then reservice your lcd, if it is cheap..
Oct 25, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor doesn't turn on anymore.
I think this should be a problem with the CPU and not the monitor, Is there a continuous beep sound coming , If so then there is a problem with the Memory.
Dec 16, 2008 | Hannspree HANNS-G 19" Widescreen Monitor
Faint green discoloured screen then screen is blank
Sounds like one of your florescent tubes have died. THe power circuit is trying to start it but fails then shuts down
Nov 10, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns-G HW173D
That once happened to my LCD screen. I had to send it to the supplier for a fix. If it's still under warrenty, try sending it back for a replacement.
Oct 27, 2008 | Hanns.G Corporation HW173D Monitor
Popping sound, black screen
Has it bitten the dust? Probably.
May 18, 2017 | Proview PL926WBi 19" LCD Monitor
Hanns g 19 inch monitor
No direct experience of this specific monitor, but LCD monitors in general seem to be susceptible to power supply failure due to the relatively cheap capacitors they use and the high working temperatures.
Turn it off, leave it for an hour or two, then take off the cover and look for bulged or leaking cap's on the power supply board. If the tops are not flat, they're probably duff, and need replacing with equivalent spec ones. Probably 105'C high temp - I got 105'C 470uF 35V ones for my monitor from Ebay at about a fiver for a pack of ten.
Aug 27, 2008 | Hanns.G Corporation HX191DP LCD Monitor
Hanns.G Corporation HU-196DP LCD Monitor Logo
642 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
