When printing an article the printer over runs the pitchure shown.
    Scholar:
  • 77 Answers
Lennyjoani- It seems you are printing a web page not printer friendly. I would recommend taking a printscreen and them printing that image. Inherently web pages are meant for display not printing.
You can try the step below and see if helps:
1. Go to the view menu of the browser
2. Go to encoding- choose western European (windows)
3. Print again
Hope this helped
Posted on Oct 10, 2008
Why does HP Deskjet 940c only print left side of a selection from a web page?
A printer prints almost anything that is shown in a computer screen and it depend on what you're trying to print. If you want to print contents from a webpage, you have two options to chose from. The first is of course the contents in the webpage that you want printed and the second option is to print the whole webpage. If you want to print only the contents in a web page, e.g. an article or photo, you have to highlight the article or photo first then right-click and select 'Print...'. It should print the article or photo only. But if you want to print the whole webpage, chances are that it only prints the 'skeleton' of the webpage and not the contents, hence the reason you have only the left part of the webpage printed. However, if you highlight the whole webpage and then right-click and select 'Print...' I am sure you will have the whole webpage printed. Cheers.
Mar 08, 2015 | HP DeskJet 940c InkJet Printer
Lexmark Pro 915 wireless print problem
Try set a static IP on your printer. Check the steps in this article: http://bit.ly/SxORCU.
After setting a static IP, set the network port to the IP address that you provided to your printer or you can reinstall the drivers.
Jul 27, 2012 | Lexmark Pro 915 All-in-one Printer W/inks...
When I print an article or page on pdf, I increase the size of the font but the printer will not print the words as shown on the screen. The print is so small that I need a fruit fly to walk across it and...
try to check your configuration on your printer setup. maybe their are settings that are affected when you change your PDF file.
Other way around is to copy paste the article from PDF going to MS word.
Aug 20, 2011 | Computers & Internet
Hi There, I have a brother DCP-130c printer and one of the colour ink has run out. I need to be able to print with just black. Is there a way to print without replacing colour ink?
When you click on print, click on print preferences. As shown in image below.
On the preferences window click on Paper Quality tab and click on black and white. As shown below.
Click on OK and then click on print.
Note: Few new printers wont print till you replace the empty cartridges.
Regards,
Shrey
May 31, 2011 | Brother DCP 130C All-In-One InkJet Printer
Hi, I cancelled a print request but the request is frozen and has been for 3 days. I have disconnected both laptop and printer from power (turned off and restarted but the print request is still in the...
1. unplug the usb cable from the printer and go to your printer list. 2. delete the installed printer. 3. once the printer is deleted from your list, plug the usb printer cable back in 4. the printer should reinstall itself and the print request should be gone
Feb 28, 2011 | HP D1560 Deskjet Printer InkJet
Our HP Color LaserJet 2600n refuses to delete a file and therefore is blocking other print jobs. The Control Panel window says it's deleting....but it's been trying to do that for two weeks. We have turned...
I'm going to assume you're using XP. I've not seen this problem yet with Vista or Windows 7, which handle the print queue differently. Sometimes the print queue gets corrupted, and a job gets "stuck" and you can't delete it. You can get rid of it this way:
  1. Click "Start" on the task bar, then "Run...".
  2. In the "Run" dialog box, type "cmd" (without the quotes) and enter.
  3. Enter the following commands as shown in the cmd.exe window that opens:
  • net stop spooler
  • del %systemroot%\system32\spool\printers\*.shd
  • del %systemroot%\system32\spool\printers\*.spl
  • net start spooler
  • exit
These steps delete the corrupted print queue, so the ghost print job will be gone. (In the commands above, "%systemroot%" is an environment variable that is filled in for you by Windows. Type it as shown.)
Microsoft has a knowledge base article which suggests using notepad to put these steps into a command file, a text file with a ".cmd" extension. Then you can just type the filename in the Run... dialog box and do less typing. This is handy if you find you need to clear the queue this way more than once in a while.
Feb 28, 2011 | HP LaserJet 4600dn Color Printer
Cannot cancel document from queue
  • net stop spooler
  • net start spooler
  • exit
Feb 17, 2011 | Lexmark X5150 All-In-One InkJet Printer
I'm trying to print an article from the computer and blank pages keep running through the printer non-stop.
Try canceling the print job, unplug the printer and plug it back in. Copy the article to a Word Doc. and print it from there.
Dec 07, 2010 | HP DeskJet 932c InkJet Printer
Printer wont print Its telling me it can't clean.See troubleshooting. did what it said and hasn't fixed the problem green light is on - but printer does not priont when print button is pushed on computor.
Hello!!
* Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
* Make sure that there is no packing material in the printer.
* Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
If the check page prints correctly, make sure that the printer software and your application are installed correctly.
* If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
* Windows Me and 98 users can clear any stalled print jobs from the Spool Manager.
* If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
If this does not work, replace the ink cartridges. See Replacing an Empty Ink Cartridge for instructions.
Nov 23, 2008 | HP DeskJet 932c InkJet Printer
When I cancel the printer does not print other items that have been scanned. it gets hung up.
when you print an article on-line. it goes into your printers memory. 10 pages for instance. if you cancel after 5 pages. the printers RAM ( memory ) stores the remaining pages to be printed. the only way to do this, is to cancel printing. then go into printer program. and delete the queue, or pending items, before exiting windows.
hope this explains your dillema.
mike @ Compurepair.
Feb 20, 2008 | HP DeskJet F380 All-In-One Printer
46 people viewed this question
jasbo
jasbo
