Question about LG 47LC7DF 47 in. LCD HDTV
47lc7df avf wall mount which is vesa is too small.The mount holes on the tv are 31 1/2 " apart and the wall mount piece is only 30 " across.
I ordered a Sanus VMB1 kit for the some problem and I believe it should fix it for mine.
Posted on Jan 14, 2009
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Can this tv be wall mounted?
Need a bit more info to be sure but most flat screens have whats known as a vesa mount. This is for a wall mount kit. Look for a group of 4 screw holes, a few inchs apart in the centre of the back of the screen. Hope this helps.
May 20, 2015 | Televison & Video
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Jun 10, 2011 | Soyo Televison & Video
I need a wall mount bracket
Most if not all tv's are VESA compatible. All wall mounts are VESA compatible, meaning you can buy any wall mount you see fit to mount your tv.
I'd look into Sanus brand mounts, they're pretty decent.
Mar 08, 2011 | Emerson LC320EM8 32 in. LCD TV
No mounting instructions in package. will it work on an LG 47 inch led tv? To many peices in the package?
It should work with the LG 47". you need to find the correct bolts that fit the mounting holds on your TV. There should be a bag of bolts packaged with the Omnimount.
Feb 28, 2011 | OmniMount 40" 70" TV Wall Mount
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
Hi i have a olevia model 532 B12 television out of my trailer and i need a stand for it how do i get one ???
Hi
The first option would be to contact Oevia direct nad see if they can supply you with one however this may be quite expensive and difficult to do.
The second option would be to buy any VESA standard mount for your TV and use this option, You can check if your TV takes this type of mount by looking on the back, there will be 4 holes around 5" apart where the mount will bolt into, you can get either cantilever wall mounts or if you look on ebay or the likes of you can usualy find secondhand VESA mounts for sale.
Hope this helps
Dec 09, 2009 | Syntax Televison & Video
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
LG 47LC7DF 47 in. LCD HDTV Logo
179 people viewed this question
Computer Repairing
Computer Repairing
