Question about Akai LCT3201AD 32 in. LCD Television
LCT3201AD TV Shutoff
LCT3201AD TV works for about 20 minutes then shuts off. It will immediately restart when the power button is pressed. This cycle continues with the run time getting shorter and shorter until it will only run a minute or less. After an extended time off, the cycle will repeat with the run time getting shorter again.
From what I have read the power supply is evidently at fault, but I have had no luck in obtaining a replacement. Is there any help you can give either repairing or telling me where I can find a replacement. Shipping you the board for repair would not be a problem.
Jerry Goss
    Scholar:
  • 124 Answers
  • Mike H. Nov 01, 2008
    The problem comes from the power supply board.
    You can have the power supply board repair or replace.
    I understand that this part is VERY hard to find. Everywhere I have contacted, they do not have any in stock and cannot get stock. Your best bet is to have it repair.
    To have it repaired, click on the below link
    http://www.power-supply-repair.com/
    If you have any additional questions, please feel free to contact me asap.
    Thanks,
    Mike
How do I set coffee maker to shut off in 2 hrs and how to use clean cycle
Not knowing which model you have, here are the instructions for my model. Perhaps yours is the same.
"The Automatic Shutoff
Time can be programmed anywhere from immediate shutoff after completion of the brew cycle up to four hours. When the coffeemaker shuts itself off, two tones will sound. Two hours is the default time. The 0:00 setting shuts the unit off immediately after brewing is complete.
To check the current setting, press and hold the On/Off button and the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the On/Off button until the red power light and LCD display begin to flash. This signals that you have entered the Set Automatic Shutoff mode.
Press the Hours and Min buttons to scroll forward through the digits until desired time appears. The first setting which appears is preset at 2:00. When it's at 4:00, the next press key of Hour will roll back to 0:00, since four hours is the maximum Automatic Shutoff setting. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The Automatic Shutoff Time (ASO) may be 8 9 programmed either before or during coffee brewing. You may also re-program the ASO time when brewing has been completed. If you do so, the Grind & Brew™ will automatically account for any time that has already elapsed after brewing. For example, if you set the ASO for 40 minutes and 25 minutes have already elapsed, the Grind & Brew™ will shut off automatically after 15 minutes (40 minutes minus the 25 elapsed equals 15 minutes)."
Mine doesn't have a specific clean cycle, but to decalcify the unit, add 1/2 vinegar to 2/3 water in a full cafree and run it through. If it's really calcified, turn off about 1/2 way through and let it set for an hour. Then turn it on and finish, Remember to run a pot of clean water through the wash out the vinegar taste.
Jun 24, 2016 | Cuisinart Coffee Makers & Espresso...
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
My power light comes on then ngoes off immediately
1. Turn off the computer
2. Removed battery and disconnected power cord .
3. Wait, for 5-10 minutes
4. Plug the power cord back in but DO NOT reinsert the battery
5. Holding down both the Insert/Scroll button, hold the power button down for 20-30 seconds, release the power button. still hold the Insert/Scroll button press the power button normally should come up and Windows should boot.
6. Restart hit ESC it should open the BIOS and reset to default. restart computer should come back.
Feb 19, 2011 | HP Compaq Presario F500 F700 and G6000...
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
tones will sound.
NOTE: Automatic shutoff may be
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
elapsed, the unit will shut off automatically
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Tv won't turn on
Although not a great solutin it does allow me to use my fairly new and expensive LCD TV. Heres what I do, UNPLUG THE TV FOR 20 -30 MINUTES, WHEN PLUGGED BACK IN YOU NEED TO VERY QUICKLY PUSH THE POWER BUTTON ON THE TV.
Let e know if this works fo you.
Mar 27, 2009 | Akai LCT3201AD 32 in. LCD Television
How to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
two tones will sound. Four hours is the default
after brewing is complete. To check the
current setting, press the “On/Off” button and
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
do so, the Automatic Grind & Brew™ will automatically
-Tha Mp3 Doctor
Mar 27, 2009 | Cuisinart Coffee Makers & Espresso...
WARMING PLATE DGB 300
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Sputters on initial startup and again also 15-20 minutes after shutoff and restart
fuel pump, clogged fuel injectors, bad gas.... could also be a timing problem among other things depending on what you mean by sputtering.... my advice find a shop that will diagnose the car for free( like AAMCO). hope this helps :)
Nov 09, 2008 | 2001 Volkswagen Beetle
Akai LCT3201AD 32 in. LCD Television Logo
81 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
