Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
One day when I turned my TV on, there was a black vertical line going down the left side of the screen about 2 inches thick with some red lines trailing it like an echo. What is this problem and can anyone fix it?
  • 2 more comments
  • xstarbladex Oct 10, 2008
    The model was Philips Magnavox 42MF230A - 42" LCD TV
  • Anonymous Dec 10, 2008
    Same problem, but on the right side... A black ghosting line...
  • harleymax Jan 10, 2009
    Vertical lines on the left side of the screen 42" Sony Wega ke-42xbr900
  • Anonymous Mar 07, 2009
    Same problem - black vertical line on right-hand side of Sony Bravia - am taking it in for repair - can let you know the outcome...
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Posted on Dec 20, 2009
LG LCD TV 42LK450 - Sound but screen is black..
Sorry but you have a bad panel. Repair cost is prohibitive. The T-con was a good choice, but is the last step to the panel.
Feb 13, 2014 | LG 42 42LK450 42 LCD TV
Vertical line on screen
Hi, This is a problem that's far too common among flat-panel and projection LCD TV's?and it's generally known as "vertical banding." If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. These faint vertical bars (often most apparent when the screen is totally dark or displaying a solid background, like the sky) are defects that occur during the manufacturing process, and while the worst offenders are typically screened out, many more make it to store shelves. Since you've pinpointed the banding and it's driving you nuts,also its under warranty, call the manufacturer and demand a replacement; in most cases, they'll capitulate and send you a new set, although you'll probably have to go to the trouble of packing and shipping back your defective TV (make sure the manufacturer covers your shipping costs). Regards sreejith
Jul 30, 2007 | Philips Magnavox 42MF521D/37 Television
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
VERTICAL COLOR LINES CAME UP ON THE SCREEN AND A HIGH PITCHED CONTINOUS NOISE. TURNED TV OFF AND TV CAME BACK ON WITH A BLACK SCREEN, NO SOUND. NOW THE TV WILL TURN ON BUT WILL NOT TURN OFF. THE...
Issue with your Vertical Holder and your Hi Voltage Regulator
..Check for Regulator Leakage on your Hi Voltage Board and Resitor over heat due to overload voltage on the Vertical holder
Cause,,, Due to Static Shoc ...Check also for bad Ground connection
Sep 22, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
Sep 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
42 samsung plasma tv
Need to get service from A/S center for replace PDP module.
Jan 25, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical Red Lines
IS IT AN LCD ? IF SO IT MAYBE THE CONNECTOR ON THE LCD PANEL THET USUALLY GO DRY JOINTED
Oct 08, 2007 | Akai PDP-4216M 42 in. Plasma Television
Televison & Video Logo
2,593 people viewed this question
Top Televison & Video Experts
Electro Med Services...
