Question about Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage
Fluke 8060AA digital multimeter
I can't get my Fluke meter 8060AA to display anything. I worked when I last used it 8 yrs ago. I replaced the 9v battery with a new good battery and cleaned the contacts. At times I could see a very dim display. Now nothing displays when it's turned on. Any ideas??
Larry
Test unit reads okay then goes into - OL mode unable to take any readings
Posted on Jul 12, 2011
  • 3 Answers
The fuse has nothing to do with the display.
The contacts of the LCD are probably oxidized because of its age. With the unit out of its care, carefully remove the LCD from its retaining mount. Use rubbing alcohol and a clean q-tip to clean the contacts of the LCD and the small "rubber-like" strips that contact both sides of the LCD. Also, remove the strips and clean the other side and the contact on the main circuit board. Then reassemble.
*Note, if you live in a cold climate, freezing of the LCD could also cause this problem. In that case you must purchase a replacement LCD from Fluke.
Posted on Jan 25, 2009
    Problem Solver:
  • 6 Answers
Open it up .there is a fuse n the inside
Posted on Oct 12, 2008
My fluke 45 multimeter displays error 6. how can i solve it?
This is explanation on Error 6 from Service Manual:
EEROM (A1U5) meter configuration corrupted or EEROM not initialized. At power up, A1U6 reads CRC from EEROM (A1U5) location, then reads configuration data from another location in EEROM, calculates an algorithm to compare to the CRC. If an error is determined, the meter configuration is set to factory default and Error 6 is displayed.
You can find service manual with troubleshooting procedure here: http://www.fluke.com/Fluke/usen/Support/Manuals/default.htm?ProductId=56082
Aug 13, 2013 | Fluke 45 Dual Display Multimeter
No beep on continuity mod
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem - this is the likely cause of your problem.Contact local Fluke authorised service centre or Fluke directly if you are in US and ask them for Audio Transducer (Part Number: 2041050). it should not be more than couple of dollars.
Mar 18, 2012 | Fluke Networks Fluke 179 Electricians...
My 23 will not work on ac setting
i dont know if this affects the reading on AC but in the back of the meter there are 2 fuses. remove the back cover and check these fuses.
Jan 12, 2010 | Fluke Networks Fluke Multimeter Combo Kit...
My fluke 337 clamp is reading 370A on DC function ALWAYS, but the other functions work fine. Someone can help to resolve this problem? Thanks.
This meter has been recalled due to a circuitboard problem which may lead to severe shock. Please go to flukes website at www.fluke.com/33xrecall to download the forms and get information to see if yours is one involved in the recall.
Jan 06, 2010 | Fluke Networks Fluke 336A Digital Clamp On...
WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND SHOWES CODE "EEPR" .
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Nov 01, 2009 | Fluke Networks Fluke 179 Electricians...
Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage Logo
265 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
