Question about LG RH177 DVD Recorder/HDD Recorder
HDD/DVD Recorder RH265 or 266
When powered on, "read" shows on screen for 15-20 seconds then machine cuts out. Then it starts up again showing "read" again. This continues repeatedly not going any further. Any suggestions as to the remedy for this? Thanks
  • 1 more comment
  • monty13 Oct 10, 2008
    Sorry, no joy with the assistance given. It's the HDD that seems to be the problem. When in standby there is no clock just lines in its place. Help! Thanks
    Hi again, there is a disc stuck in the unit, how do I remove disc to put the lens cleaner in?
  • monty13 Oct 11, 2008
    Thank you, back on track again. Will use the "FixYa Team" again!
  • 4,234 Answers
With no clock and just a few lines, the most likely problem is in the power supply. This symptom suggests a low 12V and 5V supply. This can be caused by defective capacitors amongst other things. If you are comfortable working with electronics, you may be able to resolve this yourself. Let me know and I'll try to provide more details and instructions.
Dan
Posted on Oct 10, 2008
  • 171 Answers
To remove the disc:
There is a little hole under the slot for the cd or dvd drive, and if you stick a bent paperclip, (I use a dull needle) it will make the tray slide out, or go in. If that doesn't jolt the drive back into reality, try going into the Devive Manager (Control Panel> System> Hardware) and uninstalling the drive through Windows. Windows should "find" it again on a reboot.
  • Todd Gale
    Todd Gale Oct 10, 2008
    Here how to gain access to the service menu:
    1) Press and hold together the up and down arrows on the recorder (not the remote)
    for about 6 seconds.
    2) Use the left & right buttons on the remote to move through the op codes
    And the up & down buttons to change the codes, press enter to save the changes, then menu/list button to exit. The recorder will switch off.
    Post a copy of your OP codes (only the two digits after each ops from OP1: to OP8:) and then I will tell you what you can change to get added functions and how to upgrade the firmware, getting region free etc
  • Todd Gale
    Best kept secret in the world. Here is all of the information you need to fixm upgrade, reset, improve quality and basically make this machine work like a champ.
    http://ifndef.altervista.org/index_eng.h...
    Genius:
  • 1,124 Answers
Clean the optical lector first. If the problem is with your HDD, try to reset the system.
If still problem remains trying to formatting the HDD, if doesn't work the HDD must be replaced.
  • LG Master
  • 19,396 Answers
When that happens, it means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
If that helps, don't forget to accept the solution.
  • 1 more comment
  • Ginko
    Ginko Oct 10, 2008
    Note: It is not the hard drive, when system on the HD, or HD is faulty you get an error code, you get the two lines because the system could not read the disk.
    Do the following:
    If there is a disk inside eject it.
    Unplug power for ten minutes.
    Perform lens cleaning .
    That should work.
  • Ginko
    Ginko Oct 10, 2008
    Then it is the disk stuck inside the problem, that is also reason for the two lines.
    To remove it unplug power, plug power cord back, turn on the unit, and while you are turning on keep pressing repeatedly the eject button.
    Do this several times, until it works.
    When you succeed in ejecting the disk before the unit starts reading it, you have solved the problem.
    Do not forget to accept the solution if you solve the problem.
  • Ginko
    Ginko Oct 11, 2008
    How did you solve the problem? did you format the HDD as suggested?
    Genius:
  • 3,422 Answers
HI,
Please do hard reset by unplugging all the cords of the unit for 30min and then plug it back in.Let me know if you still get the same error.
I will be waiting for your reply.
  • Priya darshan Oct 10, 2008
    If you still face the problem then you will have to send this in for a repair because a read error indicates a problem with the lens not reading the disc.
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track.
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
Jun 22, 2016 | LG RH1999H DVD Recorder/HDD Recorder
When the dvd/hdd is on it not show any picture on the tv
Do it show its Logo on screen. If it shows the logo, and does not show picture, the fault is with its pick-up lens system. If it do not show the Logo too, the fault is with its main power regulator board [SMPS]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic dmr xw350
if it uses a SATA hdd it maybe the drive is faulty & is now not booting at all. most will take a normal pc SATA hdd but check what the max size your unit can take as they have there own format & you may make the drive un-usable in a pc again. i would say get a second hand 160 - 250GB drive and try it out. as they are cheap 2nd hand.
Dec 29, 2013 | Televison & Video
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
My Sansui recorder records blank when I use the timer!
first of all make sure the time and date is set correctly on your recorder (options or set-up usually) second make sure an aerial input is going to your recorder (not just to your tv (the recorder is in the loop with aerial lead to it then from it to tv)) third make sure the on-board tuners are tuned to the correct tv channels (recorder is just a tv without a screen and has its own channels that need to be tuned in)
Jul 13, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
LG RH177 DVD Recorder/HDD Recorder Logo
234 people viewed this question
Computer Repairing
Computer Repairing
