Check sum error denioted in win xp
Error message check sum error press f 1 to start or pres del to change setup
the date and time is made the date of purchase each time y open the computer
  • 68 Answers
You internal cmos battery is flat needs replacing. then reset time and etc in bios
Posted on Oct 10, 2008
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
How to restart the computer to factory settings model type 8215-95u serial number lkndy93
to resotore the computer to factory setting is done by clearing cmos to clear cmos you need to remove the cover of the computer and search for the battery in the motherboard remove the battery and also remove the power of the hard disk then start your computer then after the post you will see boot error then shutdown the computer remove the plug from the back of the computer then insert the battery and connect the hpower to hard disk and plug in back the power supply and restart your computer when restarted you will the message cmos rested pres del to enter bios and f1 to install defult option press del and change the date and time and press F10
Jul 04, 2011 | Lenovo ThinkCentre® M52 (821595U) PC...
Hello my dear i want install 1 hard disk 320 gb and after that install win xp on my qosmio but after start setup win xp show mw did not find hard drive. how can i repair this problem? thanks
In order to be detected the hard disk drive by your windows xp installer. You have to set your sata in your cmos or bios setup. When powering your computer tap the F2 key or Del to enter cmos or bios setup, go to integrated peripherals and look for the sata controllers. Most of the times if its configured as a enhanced the windows xp can not detect it. You have to change the settings to compatible mode. Please the modify key either F5 or F6 or PGUP/PGDOWN or + or - . After changing the settings press F10 and press y and enter. Then try again running the windows setup. Have a nice day.
Feb 17, 2011 | Toshiba Qosmio G35-AV600 Notebook
When I am trying to boot up my Laptop ''Packard Bell Easynote'' I get the following message: Resource Conflict - Allocation error static node #0B Warning: Cannot Unlock Primary HDD Press Enter to resume....
you can fix that problem with your own. press f2 and then correct the time and date, then press f10. I f you got same problem again change the cmos battery then do it again.
Feb 15, 2010 | Computers & Internet
Cmos checksome error
I don't know what kind of unit you are useing.
You need to watch the screen when it boots up.
It will say check sum error, press ? F-2 to continue or F-1 to enter setup.??
Enter the setup screen and change the date and time.
Save ? F-10 and exit.
I hope this has helped you.
Oct 05, 2009 | Intel D102GGC2 Motherboard
When installing win xp from CD an error message says: no hard drives found
Just check that the hard disk is installed properly or not by checking its all cable.
If hard disk is detected then goto the bios option by pressing "DEL" or "F2" button as per your system configuration and then just find the : Native SATA support and disable it. After this save it by pressing shortcut key i.e. F10 and restart our machine.
After this start your XP setup.
Mar 03, 2009 | HP Workstation Xw8000 PC Desktop
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
Stop error
okay
first of all heck yout
RAM is fixed properly in its slot then checksystem if u get same erros again.
then u need to bootable win xp recovery or source setup disk.
if u hve then simply boot your system with c d rom in firt boot devic then follow te steps.
then go to recovry console.then typein command prompt 'chkdsk /r'
then it rstrt then if u need to repir os then pres r then folow again ame procedure but this time pres enter and u have to go to repair win xp option.
Oct 12, 2008 | Dell Latitude D600 Notebook
Cmos problem
first load bios default settings then save.
then set your date and time.
detect your hard drive if your harddrive has win xp u not need to reinstall u just detect your hardisk then restart your sys will be boot with hdd.
Mar 26, 2008 | ASUS P4S800D-X Motherboard
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
