Question about HP OfficeJet 6110 All-In-One InkJet Printer
6110 all-in-one when sending multiple pages - sends approx. 1/2 of 1st page
  • Anonymous Oct 12, 2008
    I miss my CD
  • Rakesh  Kumar
    Rakesh Kumar May 11, 2010
    newtsmom- is it a print job you are talking about or making copies using the Automatic document feeder?
    Scholar:
  • 77 Answers
Newstsmom- follow the steps below to slow down the speed at which you send the fax as the recipient machine seems to be a little old or incapable to handle the data rate. It may be the phone line too. These steps are to be followed on the frontpanel of the all in one.
People have problems when the instructions are incorrect. I as well should have read the instructions that were provided to make sure they were complete/correct.
Here are the steps in their entirety.
Press * and # at the same time, and then release both keys
Press 1, 2, and then 3, releasing each key before pressing the next.
The display window should read "Service" with a revision number.
Press the right arrow button once.
The display should read "System Configuration".
Press Enter.
Press the right arrow button until "r/w parameter" appears in the display.
Press Enter
The display should read "parameter 0"
Type in 153.
Press "Enter"
Type in 10.
Press "Enter"
Type in 159.
Press "Enter"
Type in 10.
Press "Enter"
Press "cancel" repeatedly until you are back at the date and time.
Let me know what happens.
Posted on Oct 12, 2008
It is a fax problem. All the sheets feed thru but only 1/2 of the 1st page is rec'd
Posted on Oct 11, 2008
Do not know how to scan multiple pages on the HP 6110 all in one Office jet. Please advise, Thank you, Andres
Hi
Click right mouse on the scanner icon and then change the file setting of your scanned file. Change it to pdf file not jpeg to scan in multiple pages. Another is by changing pdf to jpeg using the printer itself. Use the LCD screen menu to navigate.
Another way if you can install ADOBE ACROBAT READER PRO SOFTWARE, you can scan with multiple pages. Regads
Jun 21, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled. Doesn't matter if we are faxing one page or multiple pages.
trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled.
Apr 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
How can i send multiple fax pages in 1 transmission?
1st you dail sending No. and then all the multiple pages on fax machine.
Aug 12, 2009 | Apple HP Officejet G85xi InkJet Printer
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Open the document feeder (number panel). Make sure that a switch actuator is not stuck down.
Jun 03, 2008 | Brother IntelliFax-2820 Laser Fax
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
Apr 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Print Failure
Try printing a different application or file, try printing a test page form the printer itself does it print an internal test page? then the file has a problem.
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
