Question about Panasonic NV-GS200 Mini DV Digital Camcorder
How do I remove condensation from inside my camcorder lens?
I have condensation on the inside of my camcorder lens. This resulted from my camcorder getting wet, while a videod a youth football game. I have a panasonic pv-gs31 camcorder (3 years old). The camcorder is still in excellent working condition. However, there is a foggy spot on my picture because of the internal damp spot on my lens. How do I remove this condensation from inside my camcorder lens? My email is dcjones89@hotmail.com. My phone is 313-748-8619.
Thanks,
David Jones, Detroit, MI
    Champion:
  • 208 Answers
Place on oven @ 320F for 10 mins. flip over and add bbq sauce.. should be done. <JUST KIDDING>
leave tape out, put on sun for couple hrs.
Posted on Oct 10, 2008
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
Oct 25, 2009 | Sony Handycam HDR-HC1E HDV Digital...
InFocus LP70+ condensation/smudge INSIDE of lense
there is, but it is a pain. you need to remove the top, the cables off of the main board, the 3 screws on the main board, the spacers on the dvi connector, the rear screen (by it's screw), the fan underneath the board, the colorwheel guard, the 3 screws holding in the optical engine, then the optical engine. now you can remove the 3 screws for the lens and remove the lens. now if you can remember the spacing on the focus/zoom rings, remove the screws and unscrew the lens barrel and clean it. now put it back together. it might be easier to find another used lp70+ and swap out the parts.
Feb 22, 2009 | InFocus LP70+ Multimedia Projector
Clean lens
A can of air might get it!
Dec 09, 2008 | Canon GL1 Mini DV Digital Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Lens cap?
Try removing the battery, wait 30 seconds, and plug it back in. That may reset the lens cap sensor.
Aug 11, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Condensation
The camera has a sensor inside to detect condensation. Condensation can cause the tape to stick the the transport mechanism, resulting in possible damage.
Condensation can occur if the camera is moved from a cold environment to a warm one. The only thing you can do is open the tape compartment, remove the tape to allow maximum airflow and wait for the camera to warm up and any condensation to evaporate.
If the condensation warning had come on and your camera hasn't experienced a sudden change of temperature, this could indicate a possible fault. I'm afraid this is not something you would be able to fix yourself.
Matt
Mar 03, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Sony camcorder
condensation is the situation where a sensor detects presence of moisture inside that is hazardous to the gadget, this will not be removed if no air flow can get inside, best way is to open any side and blow hot air inside. Not hot that can damage some parts.
Feb 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Condensation
When pouring a chilled beverage into a glass, water droplets may form on the surface of the glass. This happens because the air around the glass is rapidly cooled down, and moisture in the air adheres to the surface of the glass. This phenomenon is called condensation. This kind of condensation may also occur with camcorders. If you continue to use the camcorder with condensation on it, it could damage the camcorder. Condensation may form on the camcorder in the following cases: (1) When being moved from a cold place to a warm place (2) When being used in a rapidly-heated cold room (3) When being used in a humid room (4) When being moved from an air-conditioned room to a warm, humid place When condensation occurs: The camcorder stops operating automatically after its power lamp flashes. The warning message "CONDENSATION HAS BEEN DETECTED" appears and the condensation-warning icon below starts flashing. Condensation-warning icon If a cassette is loaded, the warning message "CONDENSATION HAS BEEN DETECTED" and "REMOVE THE CASSETTE" appear and the cassette-warning icon starts flashing. Cassette-warning icon If a cassette is loaded in the camcorder, remove the cassette immediately and leave the cassette compartment open. If condensation is detected, the POWER switch and cassette-removing switch will be activated. Leaving the cassette in the camcorder may damage the tape. A cassette should not be loaded into the camcorder when condensation is detected. How to avoid condensation Unload the cassette and place the camcorder in an airtight plastic bag when moving to locations where temperatures vary. Allow time for the camcorder to adjust to temperature changes slowly before removing it from the bag. Resuming use Allow at least one hour before resuming use; more time may be required for heavier condensation. When condensation has been eliminated, turn the camcorder on. After the condensation-warning icon stops flashing, wait one hour before resuming use.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Panasonic NV-GS200 Mini DV Digital Camcorder Logo
290 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
